10-10-2019 11:19 PM - edited 07-05-2021 11:07 AM
Hi all,
With all due respect I would like to ask
I have this topology
I connect by using ssid that has been set on the WLC but I am not able to get the dhcp IP for wlan user vlan 272 and 288
any suggestion would be appricated so much
thank you
Solved! Go to Solution.
10-10-2019 11:31 PM
can you run these commands on WLC for a clinet and paste the output here!!
debug client <Mac address>
debug dhcp message enable
Dont froget to arte helpful posts
10-14-2019 12:29 AM
HI,
could you please paste the output of these commands:
show interface detailed management
show interface detailed <dynamic interface name>
Dont forget to arte helpful posts
10-10-2019 11:31 PM
10-10-2019 11:45 PM
Hi Sandeep
Thank you
but there is no output after running that command on WLC CLI
Thank you
10-11-2019 01:18 AM
Where is the DHCP server? Have you configured IP Helper-address command on switch for getting IP from the DHCP server (If DHCP in the different VLAN)?
10-11-2019 01:22 AM
10-11-2019 01:37 AM
A few questions to get more details:
1. SSID is tunneled to WLC and WLC is having correct VLAN mapping for this SSID?
2. Is this SSID VLAN trunked on the WLC management VLAN?
3. If you assigning a static IP on the client, then are you getting the Internet or Ping from the core switch?
10-13-2019 09:10 PM
Hi Deepak
sorry for late response
These are my answer according to your checking questions :
1. SSID is tunneled to WLC and WLC is having correct VLAN mapping for this SSID? Yes
2. Is this SSID VLAN trunked on the WLC management VLAN? Yes
3. If you assigning a static IP on the client, then are you getting the Internet or Ping from the core switch? No I am not able to ping
Need more insight please ;(
Thank you :)
10-14-2019 12:29 AM
HI,
