09-24-2019 10:54 PM - edited 07-05-2021 11:02 AM
Hi All,
Recently we bought a 5520-K9 WLC and AP2802I-E-K9 APs, DHCP is configured on the Switch and AP is getting IP
but unable to ping or it is not discovered
please advise
09-25-2019 12:50 AM
- Make sure that the current software version installed on the WLC is compatible with the AP-type (google on cisco wireless compatibility matrix).
M.
09-25-2019 12:57 AM - edited 09-25-2019 02:33 AM
thank you
current software version is 8.3.143.0
and compatible version is 8.2.110.0
do I have downgrade
09-25-2019 02:04 AM
09-25-2019 02:46 AM
Hi Leo,
thank you, unfortunately I cannot share the details
sorry
09-25-2019 03:10 AM
09-25-2019 08:52 AM
Make sure you have route reach ability from AP to WLC. Try to ping the WLC from the same subnet on the switch where AP is connected.
If you have network reachability and still cannot join WLC, please post show ap join stats to look into it.
09-25-2019 11:09 AM
Unable to ping what? Does the device get a gateway ip address?
If does and still does not ping on the network, you did some wrong configuration.
-If I helped you somehow, please, rate it as useful.-
09-26-2019 11:23 AM
Check your license count on the WLC.
09-27-2019 10:34 PM
Please check the access point connected switch port have the right vlan configuration to reach the wlc.
Once after connecting the access point on the switch, please take the console of the Ap and check whether the access point getting IP address or not.
check the wlc reach ability from the AP end.
Anjana
09-30-2019 04:01 AM
10-06-2019 03:49 AM
Hi All,
Managed to find out the issue the 2800 series are pre-loaded with MObility Express images so it needs to be converter CAPWAP in order to join them with a WLC
just wanted to share so it might help someone
