02-06-2014 02:40 PM - edited 07-05-2021 12:07 AM
Currenty have (2) - AIR-WLC4402-12-K9 with Software Version: 5.2.193.0 running with (12) - AIR-LAP1252AG-A-K9 Software: 5.2.193.0 IOS: 12.4(18a)JA2. I have couple question hoping you guys could help me out with them.
Thank you in advance.
02-19-2014 12:19 PM
no no not to readd.
I was just mentioned if you are adding new WLC.
****Normally cisco says that you must have higher or equal version for WCS in comparision to WLC but in my scenario i have 7.4 version WLC and that is added to WCS so dont worry about this but still keep this thing in mind.
Dont forget to rate helpful posts
02-19-2014 12:21 PM
If you have a valid smartnet on your WCS, you can upgrade to PI 1.4 for free.... something you might want to look at, of courses PI runs in a VM environment.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
02-19-2014 12:28 PM
Not an option in this scenario. But good to know.
02-19-2014 12:34 PM
Keep it in mind since the WCS is endo fo support.
Scott
02-19-2014 01:55 PM
Scott,
Just found out that the client actually do have SmartNet.Now I'm wondering if I should go for prime instead.
02-19-2014 01:58 PM
YES!!! they need to have a VM environment though. If they have that (ESXi) your good to go. Just make sure you look at the requirements for the ova you choose.
