upgrading WCS to v7.0
JackMajor
I plan on upgrading WCS from version 6.0.181.0 to 7.0230.0
Is there any reason not to or concerns?
Stephen Rodriguez
so long as you can download the code I see no reason you shouldn't. So long as WCS>= WLC you should be fine.
And the 7.0.230.0 gives you the ability to migrate your data from WCS -NCS
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
George Stefanick
As Steve pointed out you should be fine. Here is a WLC and WCS software matrix if you want that warm and fuzzy ..
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
