03-16-2015 12:12 PM - edited 07-05-2021 02:43 AM
Hello
In the Autonomous Access Point CLI I want to do a backup the network configuration on the USBFLASH: drive using the command 'archive" same as on the router CLI but unfortunately USBFLASH: is not visible in CLI of the AP. Does anyone of you is able give me some hints why the USB memory is not visible in the IOS AP?
I will be grateful
My current config is in attachment
Solved! Go to Solution.
03-16-2015 02:12 PM
Because the USB port of the 860/880/890 router is part of the router. The AP is just an "extension" that communicates with the router via a "psuedo connection". If you want to save the config of the AP, it's best to save it on a TFTP server. Use the command "sh run | redirect tftp://<TFTP IP address>/filename.txt".
03-16-2015 01:49 PM
Cisco IOS only recognizes the FAT file system. Please issue
router# format?
flash:
usbflash0:
router# format usbflash:
[YES]
Format complete
router#dir usbflash:
03-16-2015 02:08 PM
I know about it :) has been formatted to Fat32 and is not visible in ap cli...:(
03-16-2015 02:12 PM
03-16-2015 02:33 PM
you are right :) thank you for your prompt and specific response and for the reminder of the 'pseudo connection' router - ap :)
