3279
Highlighted
Beginner
use Static ip on AP, can ping to WLC but not join?
dear all,
Please kindly see in the attach file.
i using command for AP for assign ip address and AP can ping to controller but it cannot join with Controller.
Could you help to command?
Best Regards,
Rechard
12 REPLIES 12
Hall of Fame Community Legend
Post the complete output to
Post the complete output to the following commands:
1.  WLC:  sh sysinfo; and
2.  AP:  sh version
Beginner
Dear Leo, Please kindly see
Dear Leo,
i tried to use command as below and the AP can ping to Controller but the AP cannot joint to AP
capwap ap controller ip address x.x.x.x   ( IP for controller)
capwap ap ip address x.x.x.x 255.255.255.0  (IP for AP )
Best Regards,
Rechard
Post the COMPLETE output to
Post the COMPLETE output to the command "sh sysinfo".
Beginner
If you issue the debug capwap
If you issue the debug capwap client events/erros on the AP and debug capwap events/errors enable on the WLC what do you see?
Can you post it here?
Thank you
Best Regards,
Please rate helpful posts,
Ruben Carvalho CCIE#57952
Beginner
Dear all, Please kindly see
Dear all,
Please kindly see log as in the attach file.
Note: ip add 192.168.7.7 i connected to internet and remote to WLC.
i don't know why AP cannot joint to WLC. but AP can ping to Controller.
After i apply command as below if the AP cannot joint with WLC the interface BVI 1 will switch to DHCP or reboot.
capwap ap ip add 50.50.50.11 255.255.255.0
capwap ap controller ip add 50.50.50.1
Best Regards,
Rechard
VIP Mentor
Hi Rechard,
Hi Rechard,
AP: 1702I model which need the min version SW on wlc: 8.0.100.0 and you are running 8.1.102.0.
As per your logs
Unknown AP type. Using Controller Version!!!
It should support this Access Point, but looks like something wrong with software , Try to Downgrade it and try again.
Don't forget to rate helpful posts
Beginner
Dear sir, i got this log , it
Dear sir,
i got this log , it still cannot join to WLC.
AP80e0.1dfc.b050#ping 50.50.50.1
Sending 5, 100-byte ICMP Echos to 50.50.50.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
AP80e0.1dfc.b050#
*Sep 22 11:31:27.095: %CAPWAP-3-EVENTLOG: Could not discover any MWAR.
*Sep 22 11:31:27.095: %CAPWAP-3-EVENTLOG: Starting Discovery. Initializing discovery latency in discovery responses.
*Sep 22 11:31:27.095: %CAPWAP-3-EVENTLOG: CAPWAP State: Discovery.
*Sep 22 11:31:27.095: %CAPWAP-3-EVENTLOG: Not waiting for DHCP options as resolve method on interface BVI1 is 4
*Sep 22 11:31:27.095: %CAPWAP-3-EVENTLOG: spamResolveStaticGateway  - gateway NOT found
*Sep 22 11:31:30.095: %CAPWAP-3-EVENTLOG: Discovery Request sent to 192.168.7.7 with discovery type set to 1
*Sep 22 11:31:30.095: %CAPWAP-3-EVENTLOG: spamResolveStaticGateway  - gateway NOT found
*Sep 22 11:31:30.095: %CAPWAP-3-EVENTLOG: Could not resolve gateway. Ignoring WLC name lookup
*Sep 22 11:31:30.095: %CAPWAP-3-EVENTLOG: Discovery Request sent to 50.50.50.1 with discovery type set to 1
*Sep 22 11:31:30.095: %CAPWAP-3-EVENTLOG: Could not resolve gateway. Not sending discovery request to 192.168.7.7, type 1.
 SENDING DISCOVERY REQUEST wtpStartAcDiscovery:1682, Controller WLC2504: IP Address 50.50.50.1
*Sep 22 11:31:30.095: %CAPWAP-3-EVENTLOG: Discovery Request sent to 255.255.255.255 with discovery type set to 0
*Sep 22 11:31:30.095: %CAPWAP-3-EVENTLOG: Send broadcast discovery request
*Sep 22 11:31:40.095: %CAPWAP-3-EVENTLOG: Could not discover any MWAR.
*Sep 22 11:31:40.095: %CAPWAP-3-EVENTLOG: Starting Discovery. Initializing discovery latency in discovery responses.
*Sep 22 11:31:40.095: %CAPWAP-3-EVENTLOG: CAPWAP State: Discovery.
*Sep 22 11:31:40.095: %CAPWAP-3-EVENTLOG: Not waiting for DHCP options as resolve method on interface BVI1 is 4
*Sep 22 11:31:40.095: %CAPWAP-3-EVENTLOG: spamResolveStaticGateway  - gateway NOT found
*Sep 22 11:31:43.095: %CAPWAP-3-EVENTLOG: Discovery Request sent to 192.168.7.7 with discovery type set to 1
*Sep 22 11:31:43.095: %CAPWAP-3-EVENTLOG: spamResolveStaticGateway  - gateway NOT found
*Sep 22 11:31:43.095: %CAPWAP-3-EVENTLOG: Could not resolve gateway. Ignoring WLC name lookup
*Sep 22 11:31:43.095: %CAPWAP-3-EVENTLOG: Discovery Request sent to 50.50.50.1 with discovery type set to 1
*Sep 22 11:31:43.095: %CAPWAP-3-EVENTLOG: Could not resolve gateway. Not sending discovery request to 192.168.7.7, type 1.
*Sep 22 11:31:43.095: %CAPWAP-3-EVENTLOG: Send IPv4 Broadcast discovery request
VIP Mentor
Hi Rechard,use these commands
Hi Rechard,
use these commands on AP to find WLC:
capwap ap ip default-gateway <IP-address>
If still failes then please paste the complete output of this command: sh sysinfo
Beginner
Dear Sandeep, i was check on
Dear Sandeep,
i was check on cisco website the version wlc: 8.0.100.0  it not available to download.
How can i go next ?
Do you have any document or step by step to implement WLC 2504 with 1702I?
Best Regards,
Re: Dear all, Please kindly see
Please check the below things.
1. Check whether below UDP ports are allowed at the firewall end for CAPWAP Communication.
Data - 5247
Control - 5246
2. NTP time sync.
3. Appropriate Country code is enabled on the WLC.
4. Install the last TAC recommended image version 8.3.143.0.  https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn83mr4.html#concept_ejl_stn_zdb
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
Beginner
I have a 3702i, but a
I have a 3702i, but a controller running 7.4.121.0. I could ping the controller just fine from the AP's command line, but it would never join, no matter how many times I entered the CAPWAP and LWAPP commands defining the controller.
Then I realized, 3702i's aren't compatible with the older WLC controller software. I then pointed my AP to one of my newer WLC's running 8.0.121.0, and it associated immediately.
I realize this is a very simplistic answer, but it doesn't hurt to check the HCL in the release notes.
Re: use Static ip on AP, can ping to WLC but not join?
after rest the WLC please follow some steps
watch the video on my you-tube channel.
https://www.youtube.com/channel/UCh5nlwJhZKFGTm_OW04bemw?view_as=subscriber
Enter Administrative User Name (24 characters max): admin
Enter Administrative Password (3 to 24 characters): ***********
Re-enter Administrative Password : ***********
Enable Link Aggregation (LAG) [yes][NO]:
Management Interface IP Address: 192.168.10.229
Management Interface Netmask: 255.255.255.0
Management Interface Default Router: 192.168.10.1
Management Interface VLAN Identifier (0 = untagged):
Management Interface Port Num [1 to 4]:
Invalid response
Management Interface Port Num [1 to 4]: 1
Management Interface DHCP Server IP Address: 192.168.10.229
Virtual Gateway IP Address: 1.1.1.1
Multicast IP Address: 239.255.255.255
Mobility/RF Group Name: MS
Network Name (SSID): Cisco-MS
Configure DHCP Bridging Mode [yes][NO]:
Allow Static IP Addresses [YES][no]:
Configure a RADIUS Server now? [YES][no]: no
Warning! The default WLAN security policy requires a RADIUS server.
Please see documentation for more details.
Enter Country Code list (enter 'help' for a list of countries) [US]:
Enable 802.11b Network [YES][no]:
Enable 802.11a Network [YES][no]:
Enable 802.11g Network [YES][no]:
Enable Auto-RF [YES][no]:
Configure a NTP server now? [YES][no]: no
Configure the system time now? [YES][no]:
Enter the date in MM/DD/YY format: 9/10/2018
Invalid response
Enter the date in MM/DD/YY format: 09/10/2018
Invalid response
Enter the date in MM/DD/YY format: 09/10/18
Enter the time in HH:MM:SS format: 17:48:30
Configuration correct? If yes, system will save it and reset. [yes][NO]: yes
Cleaning up DHCP server configuration
Configuration saved!
Resetting system with new configuration...
Restarting system.
Content for Community-Ad
August's Community Spotlight Awards
