801
Highlighted
Beginner
Virtual WLC in LAB environment
Hi!
I have just installed a Virtual WLC at home for lab purpose. Now i want to connect one accesspoint to my wlc, but for now the WLC says "0 access points supported".
Can i somehow still use the evaluation licens and connect a accesspoint to the wlc?
/Lajja1234
1 ACCEPTED SOLUTION
VIP Mentor
Hi Lajja,You have to enable
Hi Lajja,
You have to enable the evaluation license in order to allow the AP to join.
How to do it, please check here:
http://www.cisco.com/c/en/us/support/docs/wireless/virtual-wireless-controller/113677-virtual-wlan-dg-00.html
Hope it helps.
Dont forget to rate helpful posts
2 REPLIES 2
VIP Mentor
Hi Lajja,
Hope it helps.
VIP Mentor
Also note that vWLC only
Also note that vWLC only support FlexConnect mode AP. So if you have local mode AP you need to convert it to FlexConnect mode.
Rasika
**** Pls rate all useful responses ****
Content for Community-Ad
August's Community Spotlight Awards
