ANNOUNCEMENT - The community will be down for maintenace this Thursday August 13 from 12:00 AM PT to 02:00 AM PT. As a precaution save your work.
Highlighted
Vmware unable to get the IP address from DHCP when connected on WLAN.
Vmware client (VM player) unable to get the IP address from DHCP when connected on wireless network. but the physical machine/ Laptop is  gets the ip from DHCP.
Controller 5508
Urgent!!
Any help on query would be appreciated
Laxmi
1 ACCEPTED SOLUTION
Highlighted
Advisor
You are allowed only one MAC
You are allowed only one MAC address per WiFi connection.  So you are probably using a bridged connection in VM Player, so the second device, your virtual machine will fail.
Configure the VM Player to use a NAT'ed connection (so it shares the host connection) and it should work.
I'm used to using VMWare Workstation.  Not sure how much control you have when you are only using the player.
3 REPLIES 3
Highlighted
Advisor
Highlighted
Thanks Philip  for your reply
Thanks Philip  for your reply :)
Is it a limitations of WLC or a firmware?
Highlighted
Advisor
Hmm, neither.  I think 802.11
Hmm, neither.  I think 802.11 was intended to only have one MAC address per client.
The only devices allowed more than one MAC address are "Workgroup Bridges" and "Bridges".
Content for Community-Ad
