05-13-2016 05:32 AM - edited 07-05-2021 05:03 AM
i wanted to know if is supported on Vwlc the web authenticaton local on the controller ? with local user and remote user from radius server ??
has anyone tried this config on vlwc ?
thanx all
05-14-2016 04:52 AM
Yes, this configuration is supported and will definitely work. The traffic between the client and the virtual IP address of the controller which is being used for the webauth will be encapsulated in CAPWAP. These CAPWAP packets are exchanged between the access-point and the controller. You can use local or remote authentication on the controller within this configuration.
Please rate useful posts... :-)
05-19-2016 07:44 AM
and if i use only the ldap , work ?
