04-16-2015 03:25 PM - edited 07-05-2021 02:57 AM
when try to put backup on new wlc, show me the next error
Warning! No AP will come up unless the time is set.
Please see documentation for more details.
Error: There can not be multiple maps for the field 59.1.5.0
Config CLI:config rf-profile data-rates 802.11a disabled 6 Test
some know why?
04-16-2015 03:39 PM
Edit the config and move the command which creates the RF-Profile to the top of the RF-Profile commands.
-Scott
04-17-2015 02:37 PM
Please refer below for the process of Backup
http://mrncciew.com/2013/01/25/backup-restore-wlc-configs/
04-21-2015 03:27 PM
hello,
I saw the link and, I followed step by step like to example, but showing me the same message.
assword:********* *********
(Cisco Controller) >transfer download mode tftp
(Cisco Controller) >transfer download datatype config
(Cisco Controller) >transfer download filename wlc-backup-2015-04-16
(Cisco Controller) >transfer download path .
(Cisco Controller) >transfer download serverip 10.0.0.2
(Cisco Controller) >transfer download start
Mode............................................. TFTP
Data Type........................................ Config
TFTP Server IP................................... 10.0.0.2
TFTP Packet Timeout.............................. 6
TFTP Max Retries................................. 10
TFTP Path........................................ ./
TFTP Filename.................................... wlc-backup-2015-04-16
Encrypt/Decrypt Flag............................. Disabled
Warning: Downloading configuration will cause the controller to reset...
This may take some time.
Are you sure you want to start? (y/N) y
TFTP Config transfer starting.
TFTP receive complete... updating configuration.
12-01-2015 09:43 PM
Remove out-of-box settings and this will work!
1. Go to WLAN -> AP Group then delete out-of-box group
2. Go to Wireless -> RF Profile -> Out-of-box remove the settings for Radio A and B/g/n
BOOM!
12-02-2015 12:45 AM
12-02-2015 12:58 AM
Hi mohanak,
I believe what you posted is for 58.1.5.0 error and not 59.1.5.0. I encountered the same issue with miguel and the workaround is to remove the out-of-box settings. unless miguel is using out-of-box feature which could possibly use the one you mentioned.
Cheers,
Jaccobb
12-02-2015 05:39 AM
The issue is the position of the create Rf profile on the configuration file. You need to edit the configuration file to place this command on the top of all other RF profiles. Or just remove all the rf profiles which out of box is one.
-Scott
07-28-2018 09:50 AM
12-02-2015 05:41 AM
I'm glad that this was identified as a bug:) I've just learned to make the changes agrees beating my head on the table a few times. I wish that the GUI showed the errors also, because I was able to figure this out when using the CLI.
-Scott
