WCS 7.0.164.0 - solid.exe crash
gabsfedor
last week my WCS services stopped after the program solid.exe crashed. Looking at the WCS log file and the windows event log I see that the crash came after the daily cleanup of the database was finished, then solid.exe crashed, then a bunch of java exception show up related to solid.exe. After a reboot of the server I was able to get the WCS running again and there haven't been any problems since. Has this happened to anyone else? Is there a way of keeping it from happening again?. Thanks and regards,
Gabriel.
Hi Gabriel,
We need to get intouch with the Developemnt team on this.. So the best action plan is to open up a TAC case with up.. Just heard few days back that we do hav a fix for this..
lemme know if this answered your question..
Surendra
Please dont forget to rate the posts which answered your question and mark it as answered or was helpfull
Surendra BG
5 Replies 5
Surendra BG
Here is the bug which we may be hitting..
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtf23192
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtl57406
Conatct Cisco TAC for further assistance..
Surendra
Surendra BG
Yes that does seem to be the bug that I hit. In the bug description you posted for WCS version 7 it says that the problem is fixed on version 7.0.171.68, do you know if that version has a release date set already?, the last one that is available for download is 7.0.164.3. Regards,
Gabriel.
Hi Gabriel,
Surendra
Surendra BG
OK, I will open a TAC case for it. Thanks for your help. Regards
Gabriel.
is there any update with this issue?
I`m experiencing same problem with solid.exe. and WVS version 7.0.172.0
Every two days WCS hang-up with solid.exe problem in event viewer
thanx
