WCS 7.0 - client disclaimer page
Is there a way to configure a disclaimer that will pop up on the client machine that they will need to accept to be allowed access to the wireless network?
Chris Kaufman
Stephen Rodriguez
Yes there is.  The feature is called WebAuth. and is usually configured for a guest network.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008067489f.shtml
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Amjad Abdullah
As Steve mentioned, this is only available with WebAuth so whenever your users connect and open a browser they will be redirected to a page (that you configure) and they see the disclaimer that you write. They have to press an "OK" or "Agree" button so they log into the network.
Note that this is only available with web-auth that is using open authentication. If you want to use Layer 2 authentication with key management then this is not available.
Amjad
Rating useful replies is more useful than saying "Thank you"
If you do "onboarding" with Cisco ISE you can make a disclamer before the device is registred and allowed in to the network.
