12-10-2012 08:16 AM - edited 07-03-2021 11:12 PM
We are doing a study on our public WiFi to identfy client connections based on wireless Vendor. about 40-50% of the clients wireless Vendors are "unknown". Is there a way to update the list of Vendor mac-addresses in WCS?
Chris Kaufman
Solved! Go to Solution.
12-10-2012 09:10 AM
Currently there is not a method to 'import' a list of OUI to the WCS. This gets updated with WCS software updates.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
08-30-2013 05:23 AM
I've tried :
https://supportforums.cisco.com/thread/2070671
With:
http://www.macvendorlookup.com/vendorMacs.xml.php
It's working from my point fo view.
Pavel
12-10-2012 09:10 AM
HTH,
Steve
12-10-2012 09:17 AM
Thanks Stephen )
12-10-2012 09:21 AM
Can you tell mewhen the next WCS 7.0 release is due out? 7.0.230.0 was published in Feb 2012.
12-10-2012 09:31 AM
I doubt there will be any further releases of WCS code, as it's been EOL.
http://www.cisco.com/en/US/prod/collateral/wireless/ps5755/ps6301/ps6305/end_of_life_c51-556750.html
You would need to work a migration to NCS at this point.
HTH,
Steve
12-10-2012 01:08 PM
I don't think WCS has been EOL'd. Looks to me that only the Location licenses have been EOL'd. The PLUS and Base versions still are available according to my configuration tools.
Am I reading this wrong? I just purchased WCS-Standard-K9 and WCS-Plus-100 licenses in April 2012.
Scott
08-30-2013 05:23 AM
I've tried :
With:
Pavel
