Community Helping Community
349
Beginner
WCS HA - network between primary & secondary
Looking through the WCS 7.0 config guide, one of the pre-requisites for using HA between a primary and secondary instance of WCS is: "A reliable high-speed wired network must exist between the primary WCS and its backup WCS"
Is this implying they should be physically co-located with a wire-speed switched conenction between them, or could they be located across 2 geographically separated data centres which have a reasonable speed WAN between them?
Nigel.
Everyone's tags (2)
1 REPLY 1
Its not mandatory that we need to hav it in the same LAN.. we can have it over WAN as well! but just an FYI on the below bug..
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtj23398
Lemme know if this answered ur question!!
Please dont forget to rate the usefull posts!!
Surendra
Surendra BG
Content for Community-Ad
August's Community Spotlight Awards
