02-14-2013 06:25 PM - edited 07-03-2021 11:32 PM
When i try install WCS on windows 2003 it's not possible, after double-click the WCS-STANDARD-K9-6.0.132.0 opened a little page installing "InstalAnywhere" after completed 100% i waited for few minutes but do not return any page.
resume: Do not appear the License Agreement Page
02-15-2013 05:17 AM
IIRC, the WCS after an install will come up but the license is tied to the hostname of the 2003 server. I would make sure that your server has all the hardware requirement specified in the WCS deployment guide and that you verify the md5 of the WCS file you have downloaded.
02-15-2013 06:01 AM
Ther server has CPU Intel(R) Xeon(R) E520 2.40Ghz, 8Gb RAM. Microsoft Windows Server 2003 - Enterprise Edition - Service Pack 2
For test, when i tried start by my computer Win7 the WCS can started the install but not complete because may computer don't have all requirement but the server have the requirement.
02-15-2013 06:55 AM
Yeah I don't know... I've never had an issue installing WCS on a 32 bit windows server. Did the md5 match?
02-17-2013 11:39 AM
HI Marcelo,
you must be missing some thing. you can pm me and I can go step by step with you for your installation issue thanks
02-18-2013 09:30 AM
After reinstall the operation system Windows 2003 server its gone possible installing WCS.
Thank's for your attention
