01-15-2014 07:38 PM - edited 07-04-2021 11:58 PM
I recently Installed WLC 7.5 and began a basic Web Auth Customization. I performed my usual CLI commands to upload my image, when I found a new option, tranfer download datatype icon. I tried uploading a small image to see what it would change, and I didn't see anything in particular. Does anyone know what this changes? (No it did not change the Cisco logos anywhere in the gui, at least that I could see)
(Cisco Controller) >transfer download datatype ?
code Download an executable image to the system.
config Download Configuration File.
eapcacert Download a eap ca certificate to the system.
eapdevcert Download a eap dev certificate to the system.
icon Download an executable image to the system.
image Download a web page logo to the system.
ipseccacert Download a IPSec ca certificate to the system.
ipsecdevcert Download a IPSec dev certificate to the system.
login-banner Download controller login banner. (Only Text file supported: Max 1500 bytes & 18 lines, Non printable characters not supported)
signature Download a signature file to the system.
webadmincert Download a certificate for web administration to the system.
webauthbundle Download a custom webauth bundle to the system.
webauthcert Download a web certificate for web portal to the system.
Solved! Go to Solution.
01-19-2014 08:10 PM
Hi Robinson,
sorry for the delay..
transfer download datatype icon
is the new command introduced on the WLC and this is specially for Mobile Concierge what we have.. it has more to do with Generic Advertisement Service 802.11U and please refer -
http://en.wikipedia.org/wiki/IEEE_802.11u
This to load the Icon for GAS on the WLC and has nothing do with the webauth login/logout pages..
We will make sure this gets documented on the cisco guides properly..
Please let me know if this answered your question
Surendra
01-15-2014 07:43 PM
You should create a custom WebAuth and upload that to the WLC. Might be easier. Here is a link and in this link is another link to the custom WebAuth bundles you can download.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a0080bf7d89.shtml#topic2
01-19-2014 08:10 PM
Hi Robinson,
Surendra
01-19-2014 08:34 PM
Filed a Doc bug to address this and to track this
Surendra
