Web Auth Page
Aaron Hilley
Does anyone have a good resource to create custom web auth pages?  I've modified the bundles from Cisco's website, but I am a terrible web designer.  Just curious if anyone knows of a program to make these modifications easy for someone who doesn't have this skill set.
Scott Fella
You need to find someone to do the work to be honest.  Yeah there are sites that can help build a web site, some might be free or you have to pay, but you need to insert the java script in order to make it work.  If you want something real fancy, your better off paying someone (web designer) to do the work.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Sandeep Choudhary
HI Aaron,
No boday can teach you here on this forum.
Check this link:
http://www.w3schools.com/html/
Scott Fella
Scott
-Scott
Thanks!  That is what I kind of figured, but I just wanted to check and see if someone had a "drag and drop" type application they have used to create someone a little nicer than the bundles.  I wasn't looking for anyone to teach me, just to point me in the right direction.
Aaron
I use Microsoft Expressions, but I don't know if you call that drag and drop,  You have a split window so you can see the code along with the browser.  This way you can actually type on the browser preview and it will generate the code and vice versa.  Here are some others, but might not be free:
http://www.ultraedit.com/support/tutorials_power_tips/ultraedit/integrated_html_preview.html
http://www.coffeecup.com/html-editor/
http://liveditor.com/index.php
Scott
-Scott
