Webauth drops after authentication
kevinhobson2000
Hi All
I have setup a WLAN with Web Auth using radius to authenticate per user.
The login page comes up ok and the radius autheticates but then right after logging in you get page can not be displayed and the you cant get anywhere on the WIFI.
It works ok if you use a preshared key but it has to be per user auth and i would like to stay away from PKI.
Has anyone ever come across this?
Kev
9 Replies 9
Scott Fella
Most likely your failing on the radius side or the radius isn't sending the accept correctly to the WLC. If you see pass authentication on the radius, look at the client on the WLC and see I'd the client is in the RUN state or not. Why use webauth along with radius? I know it works, but if its for guest users, I would rather put the credentials on the WLC. I wouldn't use any layer 2 authentication either, but you might have a different reason why.
-Scott
Hi Scott,
Thanks for the reply.
The idea with radius is so they can manage who can access the network by adding and removing from a group in AD.
The debug did show the radius accepted the authentication.
Scott Fella
Make sure that the service type is set to login not framed if your using IAS or NPS.
-Scott
Scott,
Ive added service-type=login.
It is NPS ill get it tested and let you know.
Thanks for the help.
Cheers
Kev
Let me know... That should fix it.
-Scott
Hi Scott,
I have got a bit further with this now.
Something strange is going on with the network.
If i do a nslookup i see the dns reply hit the switch but i dont see it go out of the port the WLC is connected to.
Cheers
Kev
What you need to look for is traffic coming back from the radius and that on the wlc the client is in the run state.  If you have a network issue, it would be after the client is in the run state.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Hi Scot,
Ive decided to change this to dot11x.
I have setup a root ca on the Network Policy Server and have configured to use this cert for PEAP as per the Cisco Guide and done the same on the client.  Identify Server Cert etc.
I am getting in the security log on the NPS:
An error occurred during the Network Policy Server use of the Extensible Authentication Protocol (EAP). Check EAP log files for EAP errors.
Kev
I sorted this by changing the cert used for PEAP to the Web SSL one.
Cheers
Kev
