04-27-2017 02:17 PM - edited 07-05-2021 06:56 AM
Hi team,
I want to validate if the code AIR-CT5520-K9-8-2-130-0.aes for a WLC-5520-K9 supports WEP security Metod for WLANs:
The link for the release notes is: http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn82mr2.html
When I try to configure a SSID with WEP Security, the SSID is not propagate, but when I change the type of security to WAP or other... It works!!! I try to upgrade but same results and the older versions in Cisco Download portal are deferred.
There's any I can do to fix this issue or download older versions of AirOS for WLC-5520???
Thanks for your help
Nestor Gomez
04-27-2017 02:49 PM
Hi Nestor,
Under Static WEP parameters, choose the WEP key size and key index
Note:- The key size can be either 40 bits or 104 bits. The key index can be between 1 and 4. One unique WEP Key Index can be applied to each WLAN. Because there are only four WEP Key Indexes, only four WLANs can be configured for Static WEP Layer 2 encryption.
One of the Cisco's useful document for this is the following. Follow the instruction given in that:-
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/82135-wlc-authenticate.html
Please rate if this will be helpful.
04-27-2017 03:03 PM
Thanks in advance for your response, based on your answer I have the next scenario:
1. WLC-5520-K9 with AIR-CT5520-K9-8.2-130.aes
2. Two models of APs: AIR-AP1832I-A-K9 and AIR-AP2802E-A-K9
3. Two SSIDs with Static WEP Auth
Is this possibble to configure or there's any issue on this scenario????
Nestor Gomez
04-27-2017 09:00 PM
May I ask why you need to use wep? I use to break wep for fun many years ago ..
04-28-2017 12:24 PM
Our customer is using wep on it's infrastructure a long ago... :P And they dislike changes... (Just a little bad)
04-28-2017 07:13 PM
I'd say ... crack open a wel crack utility and show them how easy to be owned might change their mind ..
04-28-2017 06:12 AM
In Static WEP, key index can be between 1 to 4 so you cna define maximum 4 SSID's with static WEP. Your scenario looks good but you also need to do some settings on wireless client as well to make it work. Follow the instruction defined in link provided by me in my last reply.
Please rate if you find this is helpful.
