WES610N as an adapter connecting to 3602i and WLC 2504
ewood2624
Level 5
Level 5
I've got a wes610n Cisco/Linksys that I'm trying to connect to our wireless network to use as a network adapter.  I was able to get it connected to the network with a static address to the wireless, but I cannot ping it.  On the wlc it shows connected and in RUN status but will not ping in or out.  The ssid is using just a WPA2/PSK password and it matches on both the wlc and the wireless client.  I've run a debug client (mac) on the wlc and it keeps giving this message:
*apfMsConnTask_2: May 31 07:59:49.529: Stats update: Non Zero value
I've looked throughout Cisco documentation and cannot find it.  I'm running 7.4.100.0 on the wlc with a 3602i AP.
Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Enabled
         TKIP Cipher............................. Enabled
         AES Cipher.............................. Disabled
      WPA2 (RSN IE).............................. Enabled <-- Disable this
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled <-- Disable this
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
9 Replies 9
Scott Fella
Post your show wlan   Can other devices connect and have you upgraded the driver for that device?  Ethernet bridges are difficult to get working as they don't like many settings on the WLC.  So post your show wlan and let us check that out first.
Scott
-Scott
Here is something I have found
http://www.cisco.com/en/US/products/ps6366/products_qanda_item09186a00808b4c61.shtml
Q. Are Linksys Ethernet Bridges supported in a Cisco Wireless Unified Solution?
A. No, the WLC supports only Cisco WGB products. Linksys WGBs are not supported. Although the Cisco Wireless Unified Solution does not support the Linksys WET54G and WET11B Ethernet Bridges, you can use these devices in a Wireless Unified Solution configuration if you use these guidelines:
  • Connect only one device to the WET54G or WET11B.
  • Enable the MAC cloning feature on the WET54G or WET11B to clone the connected device.
  • Install the newest drivers and firmware on devices connected to the WET54G or WET11B. This guideline is especially important for JetDirect Printers because earlier firmware versions cause problems with DHCP.
Note: Other third-party bridges are not supported. The steps mentioned can also be tried for other third-party bridges.
Scott
-Scott
I do have a Buffalo WLI-TX4-AG300N on my wireless, but it has to be rebooted once a week or so.  I had to enable passive client on the WLAN advanced tab.
Scott
-Scott
(Cisco Controller) >show wlan 2
WLAN Identifier.................................. 2
Profile Name..................................... HP-Guest
Network Name (SSID)..............................HP-Guest
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Client Profiling Status ....................... Disabled
   DHCP ......................................... Disabled
   HTTP ......................................... Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 1
Exclusionlist.................................... Disabled
Session Timeout.................................. 86400 seconds
User Idle Timeout................................ 300 seconds
--More-- or (q)uit
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... fmc01a2504
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ hpidc
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
mDNS Status...................................... Enabled
mDNS Profile Name................................ default-mdns-profile
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream      Downstream
Average Data Rate................................   0             0
Average Realtime Data Rate.......................   0             0
Burst Data Rate..................................   0             0
Burst Realtime Data Rate.........................   0             0
Per-Client Rate Limits........................... Upstream      Downstream
--More-- or (q)uit
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Disabled
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Disabled
   Accounting.................................... Disabled
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Security
--More-- or (q)uit
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
                                                               Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
         CCKM.................................... Disabled
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
         PMF-1X(802.11w)......................... Disabled
         PMF-PSK(802.11w)........................ Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Enabled
      GTK Randomization.......................... Disabled
--More-- or (q)uit
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
   WAPI.......................................... Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Disabled
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Optional
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
--More-- or (q)uit
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flow Monitor Name................................ None
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
802.11u........................................ Disabled
MSAP Services.................................. Disabled
This is wrong
You need to either use WPA/TKIP or WPA2/AES.... try WPA/TKIP first then try WPA2/AES.
Also enable passive client
Scott
-Scott
I enabled the passive client and changed the cipher for WPA and WPA2 but still no bueno
Scott
-Scott
That worked....Thanks for all your help
So now what you can do is use WPA2/AES, since you know that WPA/TKIP works
      WPA (SSN IE)...............................Disabled
          TKIP Cipher.............................Disabled
Scott
-Scott
