11-22-2018 12:26 AM - edited 07-05-2021 09:29 AM
Solved! Go to Solution.
11-22-2018 02:00 AM
That is how it should work, not sure about different behavior on recent codes.
I had a packet capture from a WLC & I saw dynamic interface sending DHCP Discover messages to both primary & secondary DHCP server in it.
Rasika
*** Pls rate all useful responses ***
11-22-2018 01:28 AM
Hi Mark,
Dynamic interface should send DHCP discovery messages to both DHCP servers configured.
Rasika
11-22-2018 01:46 AM
without sounding to offish ....
Do you know if this is actually how they operate or maybe differs depending on code (as in ... the cisco way vs the out in the field)
thanks
11-22-2018 02:00 AM
Rasika
11-22-2018 06:06 AM - edited 11-22-2018 06:07 AM
Agree with Rasika it forwards to both servers, that's how it work for us, primary & secondary - live/live.
Not aware of any differences on different code versions.
So that suggests the problem was not your WLC but rather your DHCP server or routing/firewalls/ACLs between the WLC and your secondary DHCP server.
