12-06-2019 02:31 AM - edited 07-05-2021 11:24 AM
I have a AIR-CT8540-K9 running version 8.2.167.6 which doesn't have 802.1AX. The recommend version is 8.5.151.0 Can anyone tell me if this has 802.1AX? I know 8540 Wireless Controller does have 802.1AX but I can't find out when it was added.
Solved! Go to Solution.
12-06-2019 03:19 AM
Hi, the support of 802.11AX begins in version 8.9.100.
You can find this information in the release note : https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn89.html
Please rate useful responses
12-06-2019 03:19 AM
12-08-2019 01:49 AM
12-08-2019 02:16 AM
