Community Helping Community
86
Highlighted
Beginner
Why ISR 881w only support 802.11n 20MHz width ?
As I know , 881w can support both 20MHz and 40MHz , but after enter the wireless module configuration , I only find 20MHz option under dot11radio0 interface's channel width setting , and can not find 40-above and 40-low two options , WHY?
My 881w wireless module is AP802 , version is below ,
Cisco IOS Software, AP802 Software (AP802-K9W7-M), Version 12.4(25d)JAX1, RELEASE SOFTWARE (fc4)
I'm looking forward to your response . Thanks !
Harry
Everyone's tags (1)
2 REPLIES 2
Hi , Channel bonding is not
Hi ,
Channel bonding is not supported on 802.11b/g i.e dot11radio0 because there are already very less number of non-overlapping channels.
It should be there under 5 GHz/dot11radio1 to select 40MHz.
Dhiresh
Beginner
Get it ! BTW , do you know
Get it ! BTW , do you know 881w can support WDS feature ? Thanks !
Content for Community-Ad
August's Community Spotlight Awards
