ANNOUNCEMENT - The community will be down for maintenace this Thursday August 13 from 12:00 AM PT to 02:00 AM PT. As a precaution save your work.
Highlighted
Participant
Wifi 6 AP's (9115, 9117, 9120) with Mobility Express
I read in data sheet that 9100 AP's are going to be compatible with Mobility Express in future releases.
I read in Mobility Express Release Notes 8.9.111.0 that Cisco Catalyst 9100 are compatible as subordinate AP's with Mobility Express. What does it mean?
Can I use them with a CAPWAP image conencting to a Mobility Express controller?
Has anyone tested? any problem?
Everyone's tags (1)
3 REPLIES 3
Highlighted
VIP Mentor
Re: Wifi 6 AP's (9115, 9117, 9120) with Mobility Express
Unfortunately i dont have the latest APs from cisco ;)
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/89/release_notes/b_ME_RN_89.html
If its written that 9100 are compatible iwth cisoc ME as subordinate AP then yes you can join it(CAPWAP) to ME WLC.
Dont forget to rate helpful posts
Highlighted
Hall of Fame Master
Subordinate ap means it can join a ME master ap, but can’t be a master ap. So to me, it means you would use a compatible aireos ME ap and then you can have a 91x0 join that controller.
-Scott
Highlighted
VIP Advocate
That means you need a 2800 (for example) running as Mobility Express master with 8.9.x or newer. Then the 91xx series can join to that 2800 as subordinate (client) APs.
The next few days/weeks a new image for the 91xx should be released, with ME Master capability (although with a new name, not anymore Mobility Express). It's the same software as on the 9800 WLC.
Content for Community-Ad
