Highlighted
Beginner
WIFI Radio Will Not Activate
I recently (Tuesday) purchased a WAP 321 to replace a router I had been using. I set it up as per the instructions but when connected the radio does not activate. I have tried to reset and re-install several times without success. Suggestions?
2 REPLIES 2
Highlighted
Enthusiast
Devices Can’t Connect using
Devices Can’t Connect using Wi-Fi
Complete the Setup Wizard. The Wi-Fi radio on the device is turned off
by default, and the Setup Wizard activates it. For users who do not wish
to use the Setup Wizard, log into the device using a Cat5e Ethernet
cable, and activate the Wi-Fi radi
o manually. See the Administration
Guide for details on activating the Wi-Fi radio.
Administration Guide
Highlighted
Please refer to the links
Please refer to the links-
http://sbkb.cisco.com/CiscoSB/GetArticle.aspx?docid=a51a7ab259e4403ea147508f247e5946_configuration_of_wireless_settings_in_802_11b_g_mode.xml&pid=2&converted=0
http://sbkb.cisco.com/CiscoSB/ukp.aspx?pid=2&vw=1&articleid=2201
Content for Community-Ad
Cisco COVID-19 Survey
