06-17-2016 04:14 AM - edited 07-05-2021 05:14 AM
I'm doing tests with a WLC 4404 and two APs 1142 to know how this controller manage the wifi user mobility but I see that when I change of AP my smartphone lost the Internet conection during several second.
The smartphone doesn't lost the wifi signal but I lost the Internet connectivity.
Note: The APs are installed arround 10-15 between them so it not a problem with the wifi coverage.
On the WLC logs I see a reauthentication proccess when I walk from one APs to the another one (on the moment that I have the outage)
I suppose this is normal beacuse the smartphone is reconnecting to another APs but I'm not sure.
I'm looking information about that but I'm very frustate because I don't find nothing to attack the problem.
Can anybody show me the way to attack this issue?
Thanks in advance,
06-17-2016 05:26 AM
If mobility group is configured correctly, roaming will not have any impact on user traffic (no outage)
I'll paste 2 links that can help you on checking how mobility had to be configured :
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/107188-mobility-groups-faq.html
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-0/configuration/guide/c70/c70mobil.html
After checking these documents let me know if to have further questions
PS: Please don't forget to rate and mark as correct answer if this solved your issue
06-17-2016 10:30 AM
Do this remove all security and try it on an open network and see if it improves. Also what device is it ? BTW thats a very old controller...
06-20-2016 04:10 AM
Supportlan,
Is it neccesary to configure the mobility?
I thought that options was neccesary when it's used more than one WLC.
George,
I would like to have another but at this moment it's no possible :-)
Anyway...I repeat the probe with anoter SSID with only one user connected to it (with & without security enabled) and... in this case it's work. I don't lost the connectivity anytime. Why is it possible?
The only differents that I found at this moment is....the user number connecter to the other SSID is greater. Do the user number affect to that?
06-20-2016 04:26 AM
Mobility is for sure with multiple wlc and I thought you had more than 1, sorry.
With only 1 wlc, impact are caused by number of users on 1 AP (how many users you have on 1 AP?)
It could be also when radio are misconfigured ( roaming value, RRM).
Did you leave default values?
06-21-2016 12:11 AM
I have about 5 users per AP.
I didn't change nothing about the radio settings and the wlan has been created without change any option expcept the HREAP option.
I use the following option on the HREAP settings:
I'm using the same setting on both wlan.
I don't understand why I can move me with one wlan and not with the other.
06-21-2016 01:01 AM
Do you know if are there any restriction with the characters used on the PSK?
If I remove the character "&" in my key.... work!!!
I'm doing more probes to confirm that with more devices.
06-21-2016 05:14 AM
Which version of wlc are you using?
06-21-2016 07:10 AM
It's the version 7.0.235.3
06-21-2016 07:31 AM
Very version. Have you tried to upgrade to the last recommended version?
06-21-2016 07:57 AM
Yes, it's a old version.
I would like to upgade but I don't have user to download it :-(
Anyway, I'll try to do it,
Do you heard something about this kind of issue before on this versions?
I'm going to do more test to confirm the fix.
06-21-2016 08:03 AM
It's been a while I'm not using this version but I had some bugs that were all addressed with version 7.6.
I can't remember is there were some issues with special characters within psk and/or flexconnect roaming issues.
I would highly recommend to upgrade before troubleshooting and maybe calling TAC case if needed
