Cisco Community Designated VIP Class of 2020
927
Highlighted
Enthusiast
wifi ssid deleted from wlc by it self after creation
dear all
i have problem with my wifi office ssid , every time i created new ssid it took from week to 10 days then deleted by it self from WLC  and this is the third time doing that , i created another one now just as temp solution till gonna be fixed
i already attached some pics and also the latest logs for today after its disappeared by it self
the wlan number 3 that im creating every time and its deleted
any body can help please
amr alrazzaz
1 ACCEPTED SOLUTION
VIP Advocate
Re: wifi ssid deleted from wlc by it self after creation
You should save after every config change. The save function saves the current running configuration (in RAM) to the startup configuration (on built-in flash drive). This is a safety feature in case you configure something which makes the device unreachable. In that case just plug the power and it's back to the old configuration.
There is no different between a reload and a physical power cycle.
9 REPLIES 9
VIP Mentor
Did you save the configuration after creating SSID ?
Did you try any other browser ?
Which software version you are using on WLC?
Dont forget to rate helpful posts
Enthusiast
its already created only and now its working becuase im just created  ssid before 3 hrs .. should i click on save configurations ? and why its keep working for 10 days and deleted by it self again ??
the browser is the problem ? let me try but my issue is why the ssid disappeared from wlc after created with in 10 days or 2 weeks maybe less
(Cisco Controller) >show run-config
Press Enter to continue...
System Inventory
NAME: "Chassis" , DESCR: "Cisco 3500 Series Wireless LAN Controller"
PID: AIR-CT3504-K9, VID: V01, SN: FCW2219M0E4
Burned-in MAC Address............................ 00:BC:60:FC:36:80
Maximum number of APs supported.................. 150
System Information
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.7.106.0
RTOS Version..................................... 8.7.106.0
Bootloader Version............................... 8.5.103.0
Emergency Image Version.......................... 8.5.103.0
OUI File Last Update Time........................ N/A
Build Type....................................... DATA + WPS
System Name...................................... WLC-CAMPINA-MOR
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.2427
Redundancy Mode.................................. Disabled
IP Address....................................... 10.245.191.10
IPv6 Address..................................... ::
Last Reset....................................... Soft reset due to RST_SOFT_RST write
System Up Time................................... 3 days 5 hrs 21 mins 45 secs
System Timezone Location......................... (GMT) London, Lisbon, Dublin, Edinburgh
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... IL - Israel
Operating Environment............................ Commercial (10 to 35 C)
Internal Temp Alarm Limits....................... -10 to 80 C
Internal Temperature............................. +69 C
Mgig Temp Alarm Limits........................... -10 to 78 C
Mgig Temperature................................. +58 C
External Temp Alarm Limits....................... -10 to 71 C
External Temperature............................. +50 C
Fan Status....................................... OK
Fan Speed Mode................................... Disable
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 2
Number of Active Clients......................... 2
OUI Classification Failure Count................. 0
System Nas-Id.................................... WLC-CAMPINA-MOR
WLC MIC Certificate Types........................ SHA1/SHA2
Licensing Type................................... RTU
USB ........................................... enabled
Backup Controller Configuration
AP primary Backup Controller ....................
AP secondary Backup Controller ..................
System Time Information:
Time............................................. Thu Aug 16 21:30:43 2018
Timezone delta................................... 0:0
Timezone location................................ (GMT) London, Lisbon, Dublin, Edinburgh
NTP Servers
NTP Version.................................. 3
NTP Polling Interval......................... 600
Index NTP Key Index NTP Server Status NTP Msg Auth Status
Redundancy Information
Redundancy Mode ................................. SSO DISABLED
Local State...................................... ACTIVE
Peer State....................................... N/A
Unit............................................. Primary
Unit ID.......................................... 00:BC:60:FC:36:80
Redunadancy State................................ N/A
Mobility MAC..................................... 00:BC:60:FC:36:80
Redundancy Management IP Address................. 0.0.0.0
Peer Redundancy Management IP Address............ 0.0.0.0
Redundancy Port IP Address....................... 0.0.0.0
Peer Redundancy Port IP Address.................. 169.254.0.0
amr alrazzaz
VIP Mentor
Hi,,
After any change on WLC, you must save the config else it will be lost once you reboot it.
As you can see that WLC was reboored 3 days ago:
Enthusiast
dear thanks
its okay i saved as u told me ,,, need to know whats the command of wlc to show the created wlc ssid ?
amr alrazzaz
VIP Mentor
Command to use on Clint seevthe ssids:
Sh wlan summary
Don't forget to rate helpful posts
Hall of Fame Master
After you do a save config, you should reboot your WLC and make sure that the plan is still there. Then wait and see if the SSID stay's or not. It should never just disappear unless you didn't save the config.
-Scott
VIP Advocate
You should also upgrade your software, you are running a deferred release with many bugs. I suggest you upgrade to 8.8.120.0, if all your APs are supported by that release (check release notes).
Enthusiast
so i have to save the config after each changes i have made on wlc then reboot to check if its still there or not ?
is there different between reboot or remove the power cable or cutoff the power totally from device and back it again ?
amr alrazzaz
VIP Advocate
Content for Community-Ad
August's Community Spotlight Awards
