03-22-2010 01:25 PM - edited 07-03-2021 06:38 PM
IN UWN solution, i have 5508 controllers and one ACS appliance which is integrated with Active directory for user authentication.if the ACS goes down how user authenticate or what work around we can do.
Solved! Go to Solution.
03-22-2010 10:35 PM
They wont. If you have your WLAN pointing at a ACS and should that ACS go down with no back up ACS, you are out of luck my friend...
03-22-2010 10:35 PM
