02-09-2005 12:23 PM - edited 07-04-2021 10:26 AM
Anyone know where I can find a wireless connector Visio stencil? You know, the one that looks like a helix or DNA constuct. I looked in the Stencils on http://www.cisco.com/en/US/products/prod_visio_icon_list.html and found the Aironet ones, but they're products only. I'm looking for the connector. I made one, but it doesn't work very well.
Any suggestions?
TIA,
Dave
02-11-2005 06:53 AM
I sent you an email with the icons. They are from Cisco and used to be listed with the Powerpoint icons however it doesn't seem like they are out there anymore.
J.
04-21-2012 08:06 AM
I too have been in search of this stencil. Would you be so kind to send me the link as well?
05-14-2012 12:44 PM
I'm also looking for the wireless connector. I'm looking for the squiggle line that matches the access point topology.
08-22-2012 12:23 AM
Let me know if this works....
08-26-2012 11:48 PM
Thanks, that makes life easier, as the one that I had was in two pieces so you had to make sure you grabbed both pieces otherwise you only moved half of the link.
03-02-2015 11:20 AM
Hi, im trying to get your wireless connector stencil but it is under a restricted area? Is there a other way to get it?
03-26-2015 07:27 PM
Please check this link for Visio connectors-
http://www.catraining.net/manual-downloads/visio/Visio-Working-with-Connectors.pdf
