Wireless Connector Visio Stencil
dwalsh
Anyone know where I can find a wireless connector Visio stencil? You know, the one that looks like a helix or DNA constuct. I looked in the Stencils on http://www.cisco.com/en/US/products/prod_visio_icon_list.html and found the Aironet ones, but they're products only. I'm looking for the connector. I made one, but it doesn't work very well.
Any suggestions?
TIA,
Dave
7 Replies 7
mainesy
I sent you an email with the icons. They are from Cisco and used to be listed with the Powerpoint icons however it doesn't seem like they are out there anymore.
J.
I too have been in search of this stencil. Would you be so kind to send me the link as well?
I'm also looking for the wireless connector.  I'm looking for the squiggle line that matches the access point topology.
Let me know if this works....
https://supportforums.cisco.com/docs/DOC-26597
Thanks, that makes life easier, as the one that I had was in two pieces so you had to make sure you grabbed both pieces otherwise you only moved half of the link.
Hi, im trying to get your wireless connector stencil but it is under a restricted area? Is there a other way to get it?
Abhishek Abhishek
Please check this link for Visio connectors-
http://www.catraining.net/manual-downloads/visio/Visio-Working-with-Connectors.pdf
