Highlighted
Beginner
Wireless Guest Access - L2 over L3 tunneling to Internet Router?
I would like to ask what are my options for implementing L2 over L3 tunneling to the Internet router only for guest wireless users, who will be gaining access via a captive portal? Based on the requirements from the customer, I believe the aim is to isolate guest traffic and prevent them from accessing any of the internal resources.
Thanks so much for your help!
Everyone's tags (1)
1 REPLY 1
Highlighted
VIP Advisor
To do L2 over L3 tunneling, you can use GRE, L2TPv3. This depends on the capabilities of your router.
However, if you're using Cisco WLC, you can set the remote AP as Flexconnect AP (Local switching) but configuring the Guest SSID to have get the captive portal from your central WLC (even if WLC is using ISE for guest portal). Before it was not possible and if I remember good, this is supported since around 1 year.
This solution with flexconnect is standard supported design and no need to expand Layer2 over Layer3 connectivity.
Hope this is answering your question.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Content for Community-Ad
