05-06-2015 09:27 AM - edited 07-05-2021 03:09 AM
How do I know if my two wireless LAN controllers (WLCs) have properly paired up?
Solved! Go to Solution.
05-06-2015 09:40 AM
Hello Stephen,
use below command
To check the redundancy state of the active WLC from the Cisco Prime ™ Network Control System (NCS), go to Device Details > Redundancy > Redundancy States
In CLI - The pair up details will be seen under - “show redundancy summary”.
05-06-2015 09:40 AM
Hello Stephen,
use below command
05-06-2015 10:00 AM
Hello stephen.bel0001,
Go to
-> Controller
-> Mobility Management
-> Mobility Groups
-> The WLC's will be listed and status will show "Up"
Hopefully this answers your question.
Please rate helpful posts.
Thanks.
