Wireless SSID's Remaining
sajad majeed
Is possible to rename one currently configured WLAN SSID's
2 Accepted Solutions
No, You have to delete & recreate with the modified name.
Rasika
**** Pls rate all useful responses. Each time you rate a response Cisco will donate $1 to Kiva ****
jmeachum
While you can not rename it you can delete and recreate it, as others have stated in this post and the one mentioned below.
There is another way not mentioned by others, but this is not the quickest or easiest method either.  Transfer the configuration file off of the controller, open it in wordpad, edit the SSID name, and then load the configuration back into the controller.
I hope this helps.
John
6 Replies 6
Rasika
abwahid
Level 4
Level 4
 Duplicate post, see below
https://supportforums.cisco.com/discussion/11591596/change-name-ssid-wireless-controller
Abhishek Abhishek
You have to delete the SSID and modify it.
jmeachum
I hope this helps.
John
sajad majeed
Correct................
From WLC code 8.0 onward you can rename the SSID without deleting it & recreating. Here is the release notes of that code
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn80.html#16248
Rasika
