Highlighted
Contributor
WiSM in 6500 running VSS (Virtual Switching System)
Any issues with running the WS-SVC-WISM-1 with Cisco Catalyst 6500 Series Virtual Switching Supervisor Engine 720 12.2.33SXH ?
Can anyone attest they have this working in production?
5 REPLIES 5
Highlighted
Re: WiSM in 6500 running VSS (Virtual Switching System)
As far as I know this module is not supported in VSS IOS. First supported module will be FWSM. I saw time line for modules date support, but I can not remember where.
Cheers
Greg
Highlighted
Contributor
Cisco Catalyst 6500 Series Switch
Q. What hardware must be deployed in conjunction with the Cisco WiSM?
A. The Cisco WiSM must be deployed with a Cisco Catalyst 6500 Series Switch and a Cisco Catalyst 6500 Series Supervisor Engine 720 (all Supervisor Engine 720 versions are supported, including the Sup720-10G-VSS).
http://www.cisco.com/en/US/prod/collateral/modules/ps2706/ps6526/prod_qas0900aecd8036434e.html
Highlighted
Highlighted
Contributor
It's true that it is compatible with a Sup720 VSS model, but I do not believe that it can run when the 6500 is in VSS mode. I also learned this a long time ago, probably in March, so I do not know if things have changed or not.
Beginner
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_tech_note09186a0080a6c202.shtml#req
The       first release of VSS and Cisco WiSM integration is supported on Cisco WiSM       software release 4.2.130.0 and later along with Cisco IOS Software Release       12.2(33)SXI IOS.
Content for Community-Ad
