08-16-2012 10:55 PM - edited 07-03-2021 10:32 PM
The problem is WiSM module not coming in OPER-UP status , it’s in Started-Keepalive status.
I did run debug wism events on cat6509 and seeing below logs:
Aug 17 05:16:02.930: WiSM-Evt:dman_cntrl_db_search_by_mac: Found mac 30e4.db38.9981 for slot/port 8/1
Aug 17 05:16:02.930: WiSM-Evt:dman_reg_arp_added: cntrl 8/1 got an ip 1.1.1.3 30e4.db38.9981/30e4.db38.9981
Aug 17 05:16:02.930: WiSM-Evt:dman_reg_arp: received a garp from 1.1.1.3/1.1.1.3
Aug 17 05:16:06.870: WiSM-Evt:dman_proc_keepalive_tmr_handler: keepalive timer expired for 8/1
Aug 17 05:16:06.870: WiSM-Evt:dman_cntrl_db_search: something wrong 15
It’s receiving garp request from controller and assign ip to controller but then keepalive time expired and it’s put the controller in started-keeplaive status.
Not sure what’s happening exactly.
Solved! Go to Solution.
08-20-2012 08:36 PM
Ok, so what is the output to the command "sh etherchann 415 summary"?
Wait a sec ... No Software Version???
Did you try to console into the WiSM line card?
On the 6500, can you post the output to the command "sh module"?
08-17-2012 07:46 AM
What causes the problem to happen? It seems your wism module was ok before so what happened and caused tios issue
08-17-2012 06:50 PM
Can you please post the command: sh wism 8 controller 1 status
08-20-2012 08:10 PM
By the way, this is a new install...
JP2-RDC-COR-01#sho wism module 8 controller 1 status
WiSM Controller 1 in Slot 8 configured with auto-lag
Operational Status of the Controller : Started KeepAlive
Service VLAN : 93
Service Port : 3
Service Port Mac Address : 30e4.db38.9981
Service IP Address : 1.1.1.3
Management IP Address : 0.0.0.0
Software Version :
Port Channel Number : 415
Allowed-vlan list : 90,800,810
Native VLAN ID : 90
WCP Keep Alive Missed : 0
08-20-2012 08:36 PM
