Highlighted
WLAN Latency on Cisco 3650 and LAP2702
I'm encountering some issues with my network installed last month. There are one Cisco 3650 MC and two LAP 2702.
Users have latency problems using this network. Laptop to laptop, there could be 400ms ping answer on the same SSID.
Do you know if there's any configuration to implement on the switch of if it's already configured for best performances ? For information, we've tried to connect on g/n on 2.4GHz and n/a on 5GHz and it's always the same.
Thanks in advance.
Nicolas
Everyone's tags (4)
9 REPLIES 9
Highlighted
Hi,Anybody to help me ?
Thanks in advcance
Highlighted
VIP Mentor
Pls attach your switch config
Pls attach your switch config to have a look
Rasika
Highlighted
Hi, Thanks for helpYou'll
Thanks for help
You'll find config attached.
Best regards
Nicolas
Highlighted
Beginner
Hi Nicolas, Do change the
Hi Nicolas,
Do change the below setting in WLC:
1. Click on Wireless>>>802.11a/n/ac and 802.11b/g/n>>>RRM>>>>TPC>>>TX power level assignment >>>fix it 1.
2. click on wireless>>>>802.11a/n/ac and 802.11b/g/n>>> network >>>>Data Rates
1 , 2, 5.5, 6 Mbps === set disabled all.
6 Mbps  === disabled
9 Mbps ==== Mandatory
Kamlesh
Highlighted
HiThanks ! I will re-install
Thanks !
I will re-install my network tomorrow. I test this configuration and tell you if it's better.
Thanks a lot.
Best Regards
Nicolas
Highlighted
Hi Always same problem after
Always same problem after applied configuration .
Average ping between two laptop connecter on 5GhZ, see file attached.
Another idea ?
Thanks in advance
Best regards
Nicolas
Highlighted
Beginner
Hi Nicolas, Can you check it
Hi Nicolas,
Can you check it after removing QoS configuration, if it come normal then there is QoS configuration error.
Kamlesh
Highlighted
Beginner
Hi Rasika, Please help me
Hi Rasika,
Please help me regarding Cisco AP 3702e not associating wlc ver 7.6.130.
New AP detail is as follows:
APa89d.21df.f198#sh ver
Cisco IOS Software, C3700 Software (AP3G2-RCVK9W8-M), Version 15.3(3)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Fri 19-Dec-14 11:25 by prod_rel_team
ROM: Bootstrap program is C3700 boot loader
BOOTLDR: C3700 Boot Loader (AP3G2-BOOT-M) LoaderVersion 15.2(4)JB, RELEASE SOFTWARE (fc1)
APa89d.21df.f198 uptime is 46 minutes
System image file is "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx"
Last reload reason:
 --More--
        agree to comply with
applicable laws and regulations. If you are unable
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP3702E-D-K9 (PowerPC) processor (revision A0) with 376810K/134656K bytes of memory.
Processor board ID FGL1909X179
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.0.110.0
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: A8:9D:21:DF:F1:98
Part Number                          : 73-15397-01
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : FOC19050J4U
 --More--
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.25Top Assembly Part Number             : 068-
05055-04
Top Assembly Serial Number           : FGL1909X179
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP3702E-D-K9
Configuration register is 0xF
Its lwapp ver 8.0.110.0.
WLC detail is:
7.6.130 wlc
7.6.1.118  associated ap ver
15.2.4.0     boot loader
should I downgrade the AP ver 7.6.1.118, client can't upgrade WLC.
kamlesh
Highlighted
VIP Mentor
Hi Kamlesh,Open a new thread
Hi Kamlesh,
Open a new thread as your issue is not related to this original thread.
Also attach AP console output while it is trying to register.
Rasika
Content for Community-Ad
August's Community Spotlight Awards
