Beginner
WLC 2100 support for iPhone and Android
I fellows,
I've a customer that have a WLC 2100 and he like to connect iPhone's and Android's to is wireless system.
Anyone knows if this is possible?
What's the version that support this?
Best regards,
Luis Matos
Everyone's tags (6)
6 REPLIES 6
Highlighted
Yes it is possible.  there is no minimum software requirement for any type of client to connect.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Highlighted
Beginner
Hi Stephen,
Thanks for your answer.
I've opened this post because the customer tried to connect and it was unable to do it.
Any tips?
Best Regards,
LM
Highlighted
Hall of Fame Master
Re: WLC 2100 support for iPhone and Android
Is the WLC configured right? If other devices can connect, then there should be no issue with these other devices. You will need to provide us the show run-config and the debug of the client.
-Scott
Highlighted
Beginner
Hi Scott,
The configuration could be the point, no doubt, but for now, I don't have the configuration, but i'll inform the customer that there's no constrains about the iPhone and Android system, and i'll recommend him to check is configuration again.
I'll ask the customer to send me the show config and i'll post it here.
Best Regards,
LM.
Highlighted
Hall of Fame Master
Please do post the config and also ask how they are setting up the iPhones or iPads. Coverage is not an issue correct?
-Scott
Highlighted
Beginner
I've just sent an email to the customer asking the configuration.
I think the coverage was not the problem.
Thank you,
LM
Content for Community-Ad
