Highlighted
Beginner
WLC 2504 - Client Disconnections
I have a problem in which windows clients laptops running win 7 or win 10 randomly disconnect from the wireless network, the network icon shows yellow triangle and the device has no internet connectivity for 2 minutes and it will reconnect or you force a disconnect.
 I have searched the forums and can seen a few cases but not a definitive resolution it seems to be firmware related but I wanted to ask you experts?
We have a 2504 controller with 30 2702 AP’s the controller was previously running 8.0.133.0 and was upgraded to 8.0.152.0 but this has not reaolved the issue.
Clients are connecting via 802.1x PEAP which authenticates via radius and our domain credentials.
I just wanted to check if anyone new of these issues and if this is a firmware issue?
The below is a similar post I found.
https://supportforums.cisco.com/t5/other-wireless-mobility-subjects/clients-disconnect-8-0-140-0/td-p/3048884
If you require any detailes infomation please let me know I just thought I would initially as it may have been a common issue.
Apprentice your time people 😀
Everyone's tags (4)
9 REPLIES 9
Highlighted
Hall of Fame Community Legend
Re: WLC 2504 - Client Disconnections
What are the different models of wireless NICs and what are their exact driver versions?
Highlighted
Hall of Fame Master
Also post the show wlan <wlan id> just to make sure your wlan configuration is okay.
Leo's direction of checking the client driver version is key to client connectivity.  Look at any signs of successful Windows clients and compare the driver versions, that would give you great insight if its a driver issue or not.
-Scott
Highlighted
Beginner
Thank you for your response its really appreciated.
Couple of examples of NIC & drivers are below.
Surface Pro - Marvell AVSTAR Wireless NIC (Driver - 15.68.9114.29)
Broadcom BCM943228HMB 802.11abgn 2x2 Wi-Fi Adapter (Driver - 6.30.223.264)
WLAN Identifier.................................. 7
Profile Name..................................... ##############
Network Name (SSID).............................. ##############
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
Client Profiling Status
Radius Profiling ............................ Disabled
DHCP ....................................... Disabled
HTTP ....................................... Disabled
Local Profiling ............................. Disabled
Radius-NAC State............................... Disabled
SNMP-NAC State................................. Disabled
Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
--More-- or (q)uit
Number of Active Clients......................... 1
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
User Idle Timeout................................ Disabled
Sleep Client..................................... disable
Sleep Client Timeout............................. 720 minutes
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... none
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ wifi_300
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
WLAN Layer2 ACL.................................. unconfigured
mDNS Status...................................... Disabled
mDNS Profile Name................................ unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream Downstream
Average Data Rate................................ 0 0
--More-- or (q)uit
Average Realtime Data Rate....................... 0 0
Burst Data Rate.................................. 0 0
Burst Realtime Data Rate......................... 0 0
Per-Client Rate Limits........................... Upstream Downstream
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
--More-- or (q)uit
Radius Servers
Authentication................................ 10.154.25.25 1812
Accounting.................................... Global Servers
Interim Update............................. Enabled
Interim Update Interval.................... 0
Framed IPv6 Acct AVP ...................... Prefix
Dynamic Interface............................. Disabled
Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Radius NAI-Realm................................. Disabled
Security
802.11 Authentication:........................ Open System
FT Support.................................... Disabled
Static WEP Keys............................... Disabled
802.1X........................................ Disabled
Wi-Fi Protected Access (WPA/WPA2)............. Enabled
WPA (SSN IE)............................... Disabled
WPA2 (RSN IE).............................. Enabled
TKIP Cipher............................. Disabled
AES Cipher.............................. Enabled
Auth Key Management
802.1x.................................. Enabled
--More-- or (q)uit
PSK..................................... Disabled
CCKM.................................... Disabled
FT-1X(802.11r).......................... Disabled
FT-PSK(802.11r)......................... Disabled
PMF-1X(802.11w)......................... Disabled
PMF-PSK(802.11w)........................ Disabled
FT Reassociation Timeout................... 20
FT Over-The-DS mode........................ Enabled
GTK Randomization.......................... Disabled
SKC Cache Support.......................... Disabled
CCKM TSF Tolerance......................... 1000
Wi-Fi Direct policy configured................ Disabled
EAP-Passthrough............................... Disabled
CKIP ......................................... Disabled
Web Based Authentication...................... Disabled
Web Authentication Timeout.................... 300
Web-Passthrough............................... Disabled
Mac-auth-server............................... 0.0.0.0
Web-portal-server............................. 0.0.0.0
Conditional Web Redirect...................... Disabled
Splash-Page Web Redirect...................... Disabled
Auto Anchor................................... Disabled
FlexConnect Local Switching................... Enabled
--More-- or (q)uit
FlexConnect Central Association............... Disabled
flexconnect Central Dhcp Flag................. Disabled
flexconnect nat-pat Flag...................... Disabled
flexconnect Dns Override Flag................. Disabled
flexconnect PPPoE pass-through................ Disabled
flexconnect local-switching IP-source-guar.... Disabled
FlexConnect Vlan based Central Switching ..... Disabled
FlexConnect Local Authentication.............. Disabled
FlexConnect Learn IP Address.................. Enabled
Client MFP.................................... Optional
PMF........................................... Disabled
PMF Association Comeback Time................. 1
PMF SA Query RetryTimeout..................... 200
Tkip MIC Countermeasure Hold-down Timer....... 60
Eap-params.................................... Disabled
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flow Monitor Name................................ NetFlow
Split Tunnel Configuration
Split Tunnel................................. Disabled
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
--More-- or (q)uit
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
802.11v Directed Multicast Service............... Disabled
802.11v BSS Max Idle Service..................... Enabled
DMS DB is empty
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Universal Ap Admin............................... Disabled
Mobility Anchor List
WLAN ID IP Address Status
802.11u........................................ Disabled
MSAP Services.................................. Disabled
Local Policy
--More-- or (q)uit
Priority Policy Name
Highlighted
Hall of Fame Master
We standardize on that driver version also and we are running v8.2 and testing v8.5.  I have a surface pro that I use at home and not really seeing issues.  So your WLAN config looks okay, I would probably disable Accounting by unchecking that check box unless you are using it, then define it.  Session timer can probably be increased.  I'm a fan of just disabling that or setting that around 12 hours or more.
I'm assuming that the AP's are in local mod and not flexconnect?
-Scott
Highlighted
Beginner
I will disable session timeout as suggested.
The AP's are running in Flexconnect at the sites which are having issues, we have 3 office's with the controller in one of these.
Thank you.
Highlighted
Enthusiast
Just curious, does your workstations have windows NLA (Network Location Awareness) enabled? I had a bizarre issue once where NLA was turning on because it thought it was on a public network, and was enabling firewall, and taking a long time to authenticate (sometimes it would not authenticate at all) and causing inconsistent network connectivity.
Highlighted
Post debug client <MAC-addr> with issue repro.
Highlighted
Beginner
Unfortunately I have been unable to capture this debug due to the drop out being random and I cannot replicate but I will continue trying.
I'm am not sure about NLA but this is something I will check.
Thank you all your help is greatly appreciated.
Highlighted
Beginner
I have managed to capture a debug client....The client dropped connction at 11:23, the laptop went to linited connectivity.
Looking at the client debug nothing happened since 11:17.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2018.01.30 11:10:38 =~=~=~=~=~=~=~=~=~=~=~=
debug client ac:e0:10:ea:11:02
(Cisco Controller) >*DHCP Socket Task: Jan 18 13:10:39.096: ac:e0:10:d5:a9:0e DHCP   server id: 10.2.25.22  rcvd server id: 10.2.25.22
*apfMsConnTask_1: Jan 30 11:10:58.654: dot1xDoesPmkIdMatchPmk2, Received 11w Flag: 0
*apfMsConnTask_0: Jan 30 11:11:15.882: dot1xDoesPmkIdMatchPmk2, Received 11w Flag: 0
*apfMsConnTask_2: Jan 30 11:14:05.238: dot1xDoesPmkIdMatchPmk2, Received 11w Flag: 0
(Cisco Controller) >*apfMsConnTask_1: Jan 30 11:16:19.598: dot1xDoesPmkIdMatchPmk2, Received 11w Flag: 0
*apfMsConnTask_5: Jan 30 11:16:35.231: dot1xDoesPmkIdMatchPmk2, Received 11w Flag: 0
*apfMsConnTask_5: Jan 30 11:17:11.466: dot1xDoesPmkIdMatchPmk2, Received 11w Flag: 0
*apfMsConnTask_7: Jan 30 11:17:55.796: ac:e0:10:ea:11:02 Processing assoc-req station:ac:e0:10:ea:11:02 AP:00:f6:63:9f:35:e0-01 thread:151c37a0
*apfMsConnTask_7: Jan 30 11:17:55.796: ac:e0:10:ea:11:02 Association received from mobile on BSSID 00:f6:63:9f:35:e9 AP Bristol-1-2
*apfMsConnTask_7: Jan 30 11:17:55.796: ac:e0:10:ea:11:02 Global 200 Clients are allowed to AP radio
*apfMsConnTask_7: Jan 30 11:17:55.796: ac:e0:10:ea:11:02 Max Client Trap Threshold: 0  cur: 4
*apfMsConnTask_7: Jan 30 11:17:55.796: ac:e0:10:ea:11:02 Rf profile 600 Clients are allowed to AP wlan
*apfMsConnTask_7: Jan 30 11:17:55.796: ac:e0:10:ea:11:02 override for default ap group, marking intgrp NULL
*apfMsConnTask_7: Jan 30 11:17:55.796: ac:e0:10:ea:11:02 Applying Interface(wifi_300) policy on Mobile, role Local. Ms NAC State 2 Quarantine Vlan 0 Access Vlan 300
*apfMsConnTask_7: Jan 30 11:17:55.796: ac:e0:10:ea:11:02 Re-applying interface policy for client
*apfMsConnTask_7: Jan 30 11:17:55.796: ac:e0:10:ea:11:02 10.41.123.136 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:2453)
*apfMsConnTask_7: Jan 30 11:17:55.796: ac:e0:10:ea:11:02 10.41.123.136 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:2474)
*apfMsConnTask_7: Jan 30 11:17:55.796: ac:e0:10:ea:11:02 Values before applying NASID - interfacetype:3, ovrd:0, mscb nasid:, interface nasid:, APgrpset:0
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 apfApplyWlanPolicy: Apply WLAN Policy over PMIPv6 Client Mobility Type
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 Check before Setting the NAS Id to WLAN specific Id ''
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 In processSsidIE:5817 setting Central switched to FALSE
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 Set Clinet MSCB as Central Association Disabled
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 Applying site-specific Local Bridging override for station ac:e0:10:ea:11:02 - vapId 7, site 'Bristol', interface 'wifi_300'
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 Applying Local Bridging Interface Policy for station ac:e0:10:ea:11:02 - vlan 300, interface id 12, interface 'wifi_300', nasId:''
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 override from ap group, removing intf group from mscb
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 Applying site-specific override for station ac:e0:10:ea:11:02 - vapId 7, site 'Bristol', interface 'wifi_300'
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 Applying Interface(wifi_300) policy on Mobile, role Local. Ms NAC State 2 Quarantine Vlan 0 Access Vlan 300
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 Re-applying interface policy for client
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 10.41.123.136 RUN (20) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:2453)
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 10.41.123.136 RUN (20) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:2474)
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 Values before applying NASID - interfacetype:3, ovrd:0, mscb nasid:, interface nasid:, APgrpset:0
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 Set Clinet AP specific apfMsAccessVlan = 300
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 This apfMsAccessVlan may be changed later from AAA after L2 Auth
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 Cleared localSwitchingVlan, may be assigned later based on AAA override
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 processSsidIE  statusCode is 0 and status is 0
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 processSsidIE  ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 STA - rates (3): 72 224 108 0 0 0 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 suppRates  statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_7: Jan 30 11:17:55.797: RSNIE in Assoc. Req.: (20)
*apfMsConnTask_7: Jan 30 11:17:55.797:      [0000] 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f
*apfMsConnTask_7: Jan 30 11:17:55.797:      [0016] ac 01 08 00
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 Processing RSN IE type 48, length 20 for mobile ac:e0:10:ea:11:02
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 Received 802.11i 802.1X key management suite, enabling dot1x Authentication
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 RSN Capabilities:  8
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 Marking Mobile as non-11w Capable
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 Received RSN IE with 0 PMKIDs from mobile ac:e0:10:ea:11:02
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 Found an cache entry for BSSID 00:f6:63:9f:35:ef in PMKID cache at index 0 of station ac:e0:10:ea:11:02
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 Removing BSSID 00:f6:63:9f:35:ef from PMKID cache of station ac:e0:10:ea:11:02
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 Resetting MSCB PMK Cache Entry 0 for station ac:e0:10:ea:11:02
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 Setting active key cache index 0 ---> 8
*apfMsConnTask_7: Jan 30 11:17:55.797: ac:e0:10:ea:11:02 unsetting PmkIdValidatedByAp
*apfMsConnTask_7: Jan 30 11:17:55.798: ac:e0:10:ea:11:02 AID 4 in Assoc Req from flex AP 00:f6:63:9f:35:e0 is same as in mscb ac:e0:10:ea:11:02
*apfMsConnTask_7: Jan 30 11:17:55.798: ac:e0:10:ea:11:02 apfMsRunStateDec
*apfMsConnTask_7: Jan 30 11:17:55.798: ac:e0:10:ea:11:02 apfMs1xStateDec
*apfMsConnTask_7: Jan 30 11:17:55.798: ac:e0:10:ea:11:02 10.41.123.136 RUN (20) Change state to START (0) last state RUN (20)
*apfMsConnTask_7: Jan 30 11:17:55.798: ac:e0:10:ea:11:02 pemApfAddMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_7: Jan 30 11:17:55.798: ac:e0:10:ea:11:02 10.41.123.136 START (0) Initializing policy
*apfMsConnTask_7: Jan 30 11:17:55.798: ac:e0:10:ea:11:02 10.41.123.136 START (0) Change state to AUTHCHECK (2) last state START (0)
*apfMsConnTask_7: Jan 30 11:17:55.798: ac:e0:10:ea:11:02 10.41.123.136 AUTHCHECK (2) Change state to 8021X_REQD (3) last state AUTHCHECK (2)
*apfMsConnTask_7: Jan 30 11:17:55.798: ac:e0:10:ea:11:02 Encryption policy is set to 0x80000001
*apfMsConnTask_7: Jan 30 11:17:55.798: ac:e0:10:ea:11:02 10.41.123.136 8021X_REQD (3) DHCP required on AP 00:f6:63:9f:35:e0 vapId 7 apVapId 1for this client
*apfMsConnTask_7: Jan 30 11:17:55.798: ac:e0:10:ea:11:02 Not Using WMM Compliance code qosCap 00
*apfMsConnTask_7: Jan 30 11:17:55.798: ac:e0:10:ea:11:02 Vlan while overriding the policy = -1
*apfMsConnTask_7: Jan 30 11:17:55.798: ac:e0:10:ea:11:02 sending to spamAddMobile vlanId -1 aclName = , flexAclId 65535
*apfMsConnTask_7: Jan 30 11:17:55.798: ac:e0:10:ea:11:02 10.41.123.136 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 00:f6:63:9f:35:e0 vapId 7 apVapId 1 flex-acl-name:
*apfMsConnTask_7: Jan 30 11:17:55.798: ac:e0:10:ea:11:02 apfPemAddUser2 (apf_policy.c:353) Changing state for mobile ac:e0:10:ea:11:02 on AP 00:f6:63:9f:35:e0 from Associated to Associated
*apfMsConnTask_7: Jan 30 11:17:55.798: ac:e0:10:ea:11:02 apfPemAddUser2:session timeout forstation ac:e0:10:ea:11:02 - Session Tout 0, apfMsTimeOut '0' and sessionTimerRunning flag is  0
*apfMsConnTask_7: Jan 30 11:17:55.798: ac:e0:10:ea:11:02 Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_7: Jan 30 11:17:55.798: ac:e0:10:ea:11:02 Func: apfPemAddUser2, Ms Timeout = 0, Session Timeout = 0
*apfMsConnTask_7: Jan 30 11:17:55.798: ac:e0:10:ea:11:02 Sending assoc-resp with status 0 station:ac:e0:10:ea:11:02 AP:00:f6:63:9f:35:e0-01 on apVapId 1
*apfMsConnTask_7: Jan 30 11:17:55.798: ac:e0:10:ea:11:02 Sending Assoc Response to station on BSSID 00:f6:63:9f:35:ef (status 0) ApVapId 1 Slot 1
*apfMsConnTask_7: Jan 30 11:17:55.798: ac:e0:10:ea:11:02 apfProcessAssocReq (apf_80211.c:9629) Changing state for mobile ac:e0:10:ea:11:02 on AP 00:f6:63:9f:35:e0 from Associated to Associated
*spamApTask4: Jan 30 11:17:55.802: ac:e0:10:ea:11:02 Successful transmission of LWAPP Add-Mobile to AP 00:f6:63:9f:35:e0
*spamApTask4: Jan 30 11:17:55.818: ac:e0:10:ea:11:02 Received ADD_MOBILE ack - Initiating 1x to STA ac:e0:10:ea:11:02 (idx 20)
*spamApTask4: Jan 30 11:17:55.819: ac:e0:10:ea:11:02 Sent 1x initiate message to multi thread task for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.819: ac:e0:10:ea:11:02 reauth_sm state transition 1 ---> 0 for mobile ac:e0:10:ea:11:02 at 1x_reauth_sm.c:53
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.819: ac:e0:10:ea:11:02 EAP-PARAM Debug - eap-params for Wlan-Id :7 is disabled - applying Global eap timers and retries
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.819: ac:e0:10:ea:11:02 Disable re-auth, use PMK lifetime.
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.819: ac:e0:10:ea:11:02 dot1x - moving mobile ac:e0:10:ea:11:02 into Connecting state
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.819: ac:e0:10:ea:11:02 Sending EAP-Request/Identity to mobile ac:e0:10:ea:11:02 (EAP Id 1)
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.848: ac:e0:10:ea:11:02 Reset the reauth counter since EAPOL START has been received!!!
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.848: ac:e0:10:ea:11:02 reauth_sm state transition 0 ---> 0 for mobile ac:e0:10:ea:11:02 at 1x_reauth_sm.c:53
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.848: ac:e0:10:ea:11:02 Received EAPOL START from mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.848: ac:e0:10:ea:11:02 dot1x - moving mobile ac:e0:10:ea:11:02 into Connecting state
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.848: ac:e0:10:ea:11:02 Sending EAP-Request/Identity to mobile ac:e0:10:ea:11:02 (EAP Id 2)
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.848: ac:e0:10:ea:11:02 reauth_sm state transition 0 ---> 0 for mobile ac:e0:10:ea:11:02 at 1x_reauth_sm.c:71
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.854: ac:e0:10:ea:11:02 Received EAPOL EAPPKT from mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.854: ac:e0:10:ea:11:02 Received EAP Response packet with mismatching id (currentid=2, eapid=1) from mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.855: ac:e0:10:ea:11:02 reauth_sm state transition 0 ---> 0 for mobile ac:e0:10:ea:11:02 at 1x_reauth_sm.c:71
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.868: ac:e0:10:ea:11:02 Received EAPOL EAPPKT from mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.868: ac:e0:10:ea:11:02 Received Identity Response (count=1) from mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.868: ac:e0:10:ea:11:02 Resetting reauth count 1 to 0 for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.869: ac:e0:10:ea:11:02 EAP State update from Connecting to Authenticating for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.869: ac:e0:10:ea:11:02 dot1x - moving mobile ac:e0:10:ea:11:02 into Authenticating state
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.869: ac:e0:10:ea:11:02 reauth_sm state transition 0 ---> 0 for mobile ac:e0:10:ea:11:02 at 1x_reauth_sm.c:71
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.869: ac:e0:10:ea:11:02 Entering Backend Auth Response state for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.887: ac:e0:10:ea:11:02 Processing Access-Challenge for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.887: ac:e0:10:ea:11:02 reauth_sm state transition 0 ---> 0 for mobile ac:e0:10:ea:11:02 at 1x_reauth_sm.c:71
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.887: ac:e0:10:ea:11:02 Entering Backend Auth Req state (id=159) for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.888: ac:e0:10:ea:11:02 WARNING: updated EAP-Identifier 2 ===> 159 for STA ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.888: ac:e0:10:ea:11:02 Sending EAP Request from AAA to mobile ac:e0:10:ea:11:02 (EAP Id 159)
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.888: ac:e0:10:ea:11:02 Allocating EAP Pkt for retransmission to mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.888: ac:e0:10:ea:11:02 reauth_sm state transition 0 ---> 0 for mobile ac:e0:10:ea:11:02 at 1x_reauth_sm.c:71
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.903: ac:e0:10:ea:11:02 Received EAPOL EAPPKT from mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.903: ac:e0:10:ea:11:02 Received EAP Response from mobile ac:e0:10:ea:11:02 (EAP Id 159, EAP Type 25)
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.903: ac:e0:10:ea:11:02 Resetting reauth count 0 to 0 for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.903: ac:e0:10:ea:11:02 reauth_sm state transition 0 ---> 0 for mobile ac:e0:10:ea:11:02 at 1x_reauth_sm.c:71
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.903: ac:e0:10:ea:11:02 Entering Backend Auth Response state for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.926: ac:e0:10:ea:11:02 Processing Access-Challenge for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.926: ac:e0:10:ea:11:02 reauth_sm state transition 0 ---> 0 for mobile ac:e0:10:ea:11:02 at 1x_reauth_sm.c:71
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.926: ac:e0:10:ea:11:02 Entering Backend Auth Req state (id=160) for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.926: ac:e0:10:ea:11:02 Sending EAP Request from AAA to mobile ac:e0:10:ea:11:02 (EAP Id 160)
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.926: ac:e0:10:ea:11:02 Reusing allocated memory for  EAP Pkt for retransmission to mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.942: ac:e0:10:ea:11:02 Received EAPOL EAPPKT from mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.943: ac:e0:10:ea:11:02 Received EAP Response from mobile ac:e0:10:ea:11:02 (EAP Id 160, EAP Type 25)
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.943: ac:e0:10:ea:11:02 Resetting reauth count 0 to 0 for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.943: ac:e0:10:ea:11:02 reauth_sm state transition 0 ---> 0 for mobile ac:e0:10:ea:11:02 at 1x_reauth_sm.c:71
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.943: ac:e0:10:ea:11:02 Entering Backend Auth Response state for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.960: ac:e0:10:ea:11:02 Processing Access-Challenge for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.960: ac:e0:10:ea:11:02 reauth_sm state transition 0 ---> 0 for mobile ac:e0:10:ea:11:02 at 1x_reauth_sm.c:71
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.960: ac:e0:10:ea:11:02 Entering Backend Auth Req state (id=161) for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.960: ac:e0:10:ea:11:02 Sending EAP Request from AAA to mobile ac:e0:10:ea:11:02 (EAP Id 161)
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.960: ac:e0:10:ea:11:02 Reusing allocated memory for  EAP Pkt for retransmission to mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.998: ac:e0:10:ea:11:02 Received EAPOL EAPPKT from mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.998: ac:e0:10:ea:11:02 Received EAP Response from mobile ac:e0:10:ea:11:02 (EAP Id 161, EAP Type 25)
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.998: ac:e0:10:ea:11:02 Resetting reauth count 0 to 0 for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.998: ac:e0:10:ea:11:02 reauth_sm state transition 0 ---> 0 for mobile ac:e0:10:ea:11:02 at 1x_reauth_sm.c:71
*Dot1x_NW_MsgTask_2: Jan 30 11:17:55.998: ac:e0:10:ea:11:02 Entering Backend Auth Response state for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.016: ac:e0:10:ea:11:02 Processing Access-Challenge for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.016: ac:e0:10:ea:11:02 reauth_sm state transition 0 ---> 0 for mobile ac:e0:10:ea:11:02 at 1x_reauth_sm.c:71
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.016: ac:e0:10:ea:11:02 Entering Backend Auth Req state (id=162) for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.016: ac:e0:10:ea:11:02 Sending EAP Request from AAA to mobile ac:e0:10:ea:11:02 (EAP Id 162)
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.017: ac:e0:10:ea:11:02 Reusing allocated memory for  EAP Pkt for retransmission to mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.017: ac:e0:10:ea:11:02 reauth_sm state transition 0 ---> 0 for mobile ac:e0:10:ea:11:02 at 1x_reauth_sm.c:71
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.033: ac:e0:10:ea:11:02 Received EAPOL EAPPKT from mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.033: ac:e0:10:ea:11:02 Received EAP Response from mobile ac:e0:10:ea:11:02 (EAP Id 162, EAP Type 25)
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.033: ac:e0:10:ea:11:02 Resetting reauth count 0 to 0 for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.033: ac:e0:10:ea:11:02 reauth_sm state transition 0 ---> 0 for mobile ac:e0:10:ea:11:02 at 1x_reauth_sm.c:71
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.033: ac:e0:10:ea:11:02 Entering Backend Auth Response state for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.051: ac:e0:10:ea:11:02 Processing Access-Challenge for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.051: ac:e0:10:ea:11:02 reauth_sm state transition 0 ---> 0 for mobile ac:e0:10:ea:11:02 at 1x_reauth_sm.c:71
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.051: ac:e0:10:ea:11:02 Entering Backend Auth Req state (id=163) for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.051: ac:e0:10:ea:11:02 Sending EAP Request from AAA to mobile ac:e0:10:ea:11:02 (EAP Id 163)
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.051: ac:e0:10:ea:11:02 Reusing allocated memory for  EAP Pkt for retransmission to mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.068: ac:e0:10:ea:11:02 Received EAPOL EAPPKT from mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.068: ac:e0:10:ea:11:02 Received EAP Response from mobile ac:e0:10:ea:11:02 (EAP Id 163, EAP Type 25)
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.068: ac:e0:10:ea:11:02 Resetting reauth count 0 to 0 for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.068: ac:e0:10:ea:11:02 reauth_sm state transition 0 ---> 0 for mobile ac:e0:10:ea:11:02 at 1x_reauth_sm.c:71
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.068: ac:e0:10:ea:11:02 Entering Backend Auth Response state for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.085: ac:e0:10:ea:11:02 Processing Access-Challenge for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.086: ac:e0:10:ea:11:02 reauth_sm state transition 0 ---> 0 for mobile ac:e0:10:ea:11:02 at 1x_reauth_sm.c:71
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.086: ac:e0:10:ea:11:02 Entering Backend Auth Req state (id=164) for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.086: ac:e0:10:ea:11:02 Sending EAP Request from AAA to mobile ac:e0:10:ea:11:02 (EAP Id 164)
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.086: ac:e0:10:ea:11:02 Reusing allocated memory for  EAP Pkt for retransmission to mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.106: ac:e0:10:ea:11:02 Received EAPOL EAPPKT from mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.106: ac:e0:10:ea:11:02 Received EAP Response from mobile ac:e0:10:ea:11:02 (EAP Id 164, EAP Type 25)
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.106: ac:e0:10:ea:11:02 Resetting reauth count 0 to 0 for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.106: ac:e0:10:ea:11:02 reauth_sm state transition 0 ---> 0 for mobile ac:e0:10:ea:11:02 at 1x_reauth_sm.c:71
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.106: ac:e0:10:ea:11:02 Entering Backend Auth Response state for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.128: ac:e0:10:ea:11:02 Processing Access-Challenge for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.128: ac:e0:10:ea:11:02 reauth_sm state transition 0 ---> 0 for mobile ac:e0:10:ea:11:02 at 1x_reauth_sm.c:71
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.128: ac:e0:10:ea:11:02 Entering Backend Auth Req state (id=165) for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.128: ac:e0:10:ea:11:02 Sending EAP Request from AAA to mobile ac:e0:10:ea:11:02 (EAP Id 165)
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.128: ac:e0:10:ea:11:02 Reusing allocated memory for  EAP Pkt for retransmission to mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.144: ac:e0:10:ea:11:02 Received EAPOL EAPPKT from mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.144: ac:e0:10:ea:11:02 Received EAP Response from mobile ac:e0:10:ea:11:02 (EAP Id 165, EAP Type 25)
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.144: ac:e0:10:ea:11:02 Resetting reauth count 0 to 0 for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.144: ac:e0:10:ea:11:02 reauth_sm state transition 0 ---> 0 for mobile ac:e0:10:ea:11:02 at 1x_reauth_sm.c:71
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.144: ac:e0:10:ea:11:02 Entering Backend Auth Response state for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.161: ac:e0:10:ea:11:02 Processing Access-Challenge for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.161: ac:e0:10:ea:11:02 reauth_sm state transition 0 ---> 0 for mobile ac:e0:10:ea:11:02 at 1x_reauth_sm.c:71
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.161: ac:e0:10:ea:11:02 Entering Backend Auth Req state (id=166) for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.161: ac:e0:10:ea:11:02 Sending EAP Request from AAA to mobile ac:e0:10:ea:11:02 (EAP Id 166)
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.161: ac:e0:10:ea:11:02 Reusing allocated memory for  EAP Pkt for retransmission to mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.178: ac:e0:10:ea:11:02 Received EAPOL EAPPKT from mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.178: ac:e0:10:ea:11:02 Received EAP Response from mobile ac:e0:10:ea:11:02 (EAP Id 166, EAP Type 25)
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.178: ac:e0:10:ea:11:02 Resetting reauth count 0 to 0 for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.178: ac:e0:10:ea:11:02 reauth_sm state transition 0 ---> 0 for mobile ac:e0:10:ea:11:02 at 1x_reauth_sm.c:71
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.178: ac:e0:10:ea:11:02 Entering Backend Auth Response state for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.200: ac:e0:10:ea:11:02 Processing Access-Accept for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.200: ac:e0:10:ea:11:02 Resetting web IPv4 acl from 255 to 255
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.200: ac:e0:10:ea:11:02 Resetting web IPv4 Flex acl from 65535 to 65535
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.200: ac:e0:10:ea:11:02 Setting re-auth timeout to 1800 seconds, got from WLAN config.
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.200: ac:e0:10:ea:11:02 Station ac:e0:10:ea:11:02 setting dot1x reauth timeout = 1800
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.200: ac:e0:10:ea:11:02 Creating a PKC PMKID Cache entry for station ac:e0:10:ea:11:02 (RSN 2)
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.200: ac:e0:10:ea:11:02 Resetting MSCB PMK Cache Entry 0 for station ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.200: ac:e0:10:ea:11:02 Setting active key cache index 8 ---> 8
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.200: ac:e0:10:ea:11:02 Setting active key cache index 8 ---> 0
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.200: ac:e0:10:ea:11:02 Adding BSSID 00:f6:63:9f:35:ef to PMKID cache at index 0 for station ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.200: New PMKID: (16)
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.200:      [0000] 37 32 ea 5c c4 71 6b 4d e9 7a 61 77 9b 01 25 97
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.200: ac:e0:10:ea:11:02 Disabling re-auth since PMK lifetime can take care of same.
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.200: ac:e0:10:ea:11:02 PMK: Sending cache delete
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.200: ac:e0:10:ea:11:02 unsetting PmkIdValidatedByAp
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.200: ac:e0:10:ea:11:02 Zeroize AAA Overrides from local for station
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.200: ac:e0:10:ea:11:02 0 PMK-update groupcast messages sent
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.200: ac:e0:10:ea:11:02 PMK sent to mobility group
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.200: ac:e0:10:ea:11:02 Sending EAP-Success to mobile ac:e0:10:ea:11:02 (EAP Id 166)
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.201: ac:e0:10:ea:11:02 Freeing AAACB from Dot1xCB as AAA auth is done for  mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.201: ac:e0:10:ea:11:02 Found an cache entry for BSSID 00:f6:63:9f:35:ef in PMKID cache at index 0 of station ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.201: Including PMKID in M1  (16)
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.201:      [0000] 37 32 ea 5c c4 71 6b 4d e9 7a 61 77 9b 01 25 97
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.201: ac:e0:10:ea:11:02 Starting key exchange to mobile ac:e0:10:ea:11:02, data packets will be dropped
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.201: ac:e0:10:ea:11:02 Sending EAPOL-Key Message to mobile ac:e0:10:ea:11:02
   state INITPMK (message 1), replay counter 00.00.00.00.00.00.00.00
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.201: ac:e0:10:ea:11:02 Reusing allocated memory for  EAP Pkt for retransmission to mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.201: ac:e0:10:ea:11:02 Entering Backend Auth Success state (id=166) for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.201: ac:e0:10:ea:11:02 Received Auth Success while in Authenticating state for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.201: ac:e0:10:ea:11:02 dot1x - moving mobile ac:e0:10:ea:11:02 into Authenticated state
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.225: ac:e0:10:ea:11:02 Received EAPOL-Key from mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.225: ac:e0:10:ea:11:02 Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.225: ac:e0:10:ea:11:02 Received EAPOL-key in PTK_START state (message 2) from mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.225: ac:e0:10:ea:11:02 Dumping RSNIE received in Association request:
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.225: 00000000: 30 14 01 00 00 0f ac 04  01 00 00 0f ac 04 01 00  0...............
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.225: 00000010: 00 0f ac 01 08 00                                 ......
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.225: ac:e0:10:ea:11:02 Dumping RSNIE received in EAPOL M2 :
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.225: 00000000: 01 00 00 0f ac 04 01 00  00 0f ac 04 01 00 00 0f  ................
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.225: 00000010: ac 01 08 00                                       ....
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.225: ac:e0:10:ea:11:02 PMK: Sending cache add
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.225: ac:e0:10:ea:11:02 Stopping retransmission timer for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.225: ac:e0:10:ea:11:02 Sending EAPOL-Key Message to mobile ac:e0:10:ea:11:02
   state PTKINITNEGOTIATING (message 3), replay counter 00.00.00.00.00.00.00.01
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.225: ac:e0:10:ea:11:02 Reusing allocated memory for  EAP Pkt for retransmission to mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.240: ac:e0:10:ea:11:02 Received EAPOL-Key from mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.240: ac:e0:10:ea:11:02 Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.240: ac:e0:10:ea:11:02 Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.240: ac:e0:10:ea:11:02 Stopping retransmission timer for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.240: ac:e0:10:ea:11:02 Freeing EAP Retransmit Bufer for mobile ac:e0:10:ea:11:02
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.240: ac:e0:10:ea:11:02 apfMs1xStateInc
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.240: ac:e0:10:ea:11:02 apfMsPeapSimReqCntInc
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.241: ac:e0:10:ea:11:02 apfMsPeapSimReqSuccessCntInc
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.241: ac:e0:10:ea:11:02 10.41.123.136 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state 8021X_REQD (3)
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.241: ac:e0:10:ea:11:02 10.41.123.136 L2AUTHCOMPLETE (4) DHCP required on AP 00:f6:63:9f:35:e0 vapId 7 apVapId 1for this client
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.241: ac:e0:10:ea:11:02 Not Using WMM Compliance code qosCap 00
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.241: ac:e0:10:ea:11:02 Vlan while overriding the policy = -1
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.241: ac:e0:10:ea:11:02 sending to spamAddMobile vlanId -1 aclName = , flexAclId 65535
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.241: ac:e0:10:ea:11:02 10.41.123.136 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 00:f6:63:9f:35:e0 vapId 7 apVapId 1 flex-acl-name:
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.241: ac:e0:10:ea:11:02 apfMsRunStateInc
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.241: ac:e0:10:ea:11:02 10.41.123.136 L2AUTHCOMPLETE (4) Change state to RUN (20) last state L2AUTHCOMPLETE (4)
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.241: ac:e0:10:ea:11:02 10.41.123.136 RUN (20) Reached PLUMBFASTPATH: from line 6756
*Dot1x_NW_MsgTask_2: Jan 30 11:17:56.241: ac:e0:10:ea:11:02 Accounting NAI-Realm: host/MANL00016.corp.well.co.uk, from Mscb username : host/MANL00016.corp.well.co.uk
*spamApTask4: Jan 30 11:17:56.241: ac:e0:10:ea:11:02 Successful transmission of LWAPP Add-Mobile to AP 00:f6:63:9f:35:e0
*DHCP Socket Task: Jan 30 11:17:56.336: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.336: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.336: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.336: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.336: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.336: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.336: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.336: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.338: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.338: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.338: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.338: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.338: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.338: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.338: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.338: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.340: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.341: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.341: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.341: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.341: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.341: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.341: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.341: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.343: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.343: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.343: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.343: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.343: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.343: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.343: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.343: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.347: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.347: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.347: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.347: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.347: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.347: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.347: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.347: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.349: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.349: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.349: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.349: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.349: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.349: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.349: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.349: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.351: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.351: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.351: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.351: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.351: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.351: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.351: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.351: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.354: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.354: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.354: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.354: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.354: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.354: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.354: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.354: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.355: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.355: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.355: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.355: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.355: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.355: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.355: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.356: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.360: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.360: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.360: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.360: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.360: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.360: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.360: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.360: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.365: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.365: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.365: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.365: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.365: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.365: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.365: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.365: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.367: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.367: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.367: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.367: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.367: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.367: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.367: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.367: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.370: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.370: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.370: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.370: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.370: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.370: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.370: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.370: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.373: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.374: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.374: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.374: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.374: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.374: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.374: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.374: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.377: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.377: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.377: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.377: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.378: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.378: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.378: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.378: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.378: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.378: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.378: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.378: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.381: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.381: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.381: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.381: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.381: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.381: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.381: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.381: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.384: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.384: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.384: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.384: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.384: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.384: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.384: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.384: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.386: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.386: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.386: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.386: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.386: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.386: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.386: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.386: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.388: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.388: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.389: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.389: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.389: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.389: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.389: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.389: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.394: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.394: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.394: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.394: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.394: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.394: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.394: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.394: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.399: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.399: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.399: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.399: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.399: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.399: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.399: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.399: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.408: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.408: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.408: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.408: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.408: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.408: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.408: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.408: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.415: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.415: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.415: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.415: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.415: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.415: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.415: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.415: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.417: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.417: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.417: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.417: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.417: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.417: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.417: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.417: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.418: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.418: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.418: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.418: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.418: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.418: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.418: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.418: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.420: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.420: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.420: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.420: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.420: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.420: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.420: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.420: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.422: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.422: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.422: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.422: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.422: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.422: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.422: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.422: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.425: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.425: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.425: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.425: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.425: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.425: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.425: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.425: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.427: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.427: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.427: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.427: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.427: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.427: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.427: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.427: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.431: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.431: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.431: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.431: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.431: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.431: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.431: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.432: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.432: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.432: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.432: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.432: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.432: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.432: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.432: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.437: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.437: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.437: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.437: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.437: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.437: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.437: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.437: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.441: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.441: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.441: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.441: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.441: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.441: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.441: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.442: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.448: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.449: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.449: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.449: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.449: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.449: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.449: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.449: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.449: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.453: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.453: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.453: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.453: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.453: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.453: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.453: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.453: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.458: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.458: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.458: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.458: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.458: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.458: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.459: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.459: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.459: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.459: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.459: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.459: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.459: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.459: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.463: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.463: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.463: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.463: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.463: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.463: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.463: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.463: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.469: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.469: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.469: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.469: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.469: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.469: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.469: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.469: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.470: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.470: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.470: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.470: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.470: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.470: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.470: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.472: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.472: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.472: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.472: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.472: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.472: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.472: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.472: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.476: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.477: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.477: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.477: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.477: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.477: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.477: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.477: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.477: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.481: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.481: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.481: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.481: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.481: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.481: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.481: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.481: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.483: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.483: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.483: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.483: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.483: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.483: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.483: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.483: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:56.489: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 329,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:56.489: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:56.489: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:56.489: ac:e0:10:ea:11:02 DHCP   xid: 0xbbc30305 (3150119685), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:56.489: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:56.489: ac:e0:10:ea:11:02 DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.41.123.136
*DHCP Socket Task: Jan 30 11:17:56.489: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:56.489: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:59.635: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 313,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:59.635: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:59.635: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:59.635: ac:e0:10:ea:11:02 DHCP   xid: 0x82744770 (2188658544), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:59.635: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:59.635: ac:e0:10:ea:11:02 DHCP   ciaddr: 10.41.123.136,  yiaddr: 0.0.0.0
*DHCP Socket Task: Jan 30 11:17:59.635: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:59.635: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:17:59.637: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 324,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:59.637: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:59.637: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:59.638: ac:e0:10:ea:11:02 DHCP   xid: 0x82744770 (2188658544), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:17:59.638: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:17:59.638: ac:e0:10:ea:11:02 DHCP   ciaddr: 10.41.123.136,  yiaddr: 0.0.0.0
*DHCP Socket Task: Jan 30 11:17:59.638: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:17:59.638: ac:e0:10:ea:11:02 DHCP   server id: 10.2.25.22  rcvd server id: 10.2.25.22
*DHCP Socket Task: Jan 30 11:17:59.638: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 313,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:17:59.638: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:17:59.638: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:17:59.638: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
(Cisco Controller) >
(Cisco Controller) >*apfMsConnTask_2: Jan 30 11:18:06.026: dot1xDoesPmkIdMatchPmk2, Received 11w Flag: 0
*apfMsConnTask_5: Jan 30 11:19:18.101: dot1xDoesPmkIdMatchPmk2, Received 11w Flag: 0
*apfMsConnTask_5: Jan 30 11:19:21.734: dot1xDoesPmkIdMatchPmk2, Received 11w Flag: 0
(Cisco Controller) >*apfMsConnTask_2: Jan 30 11:20:30.281: dot1xDoesPmkIdMatchPmk2, Received 11w Flag: 0
*apfMsConnTask_3: Jan 30 11:21:45.184: dot1xDoesPmkIdMatchPmk2, Received 11w Flag: 0
*apfMsConnTask_6: Jan 30 11:22:40.486: dot1xDoesPmkIdMatchPmk2, Received 11w Flag: 0
*apfMsConnTask_0: Jan 30 11:22:44.310: dot1xDoesPmkIdMatchPmk2, Received 11w Flag: 0
(Cisco Controller) >*apfMsConnTask_7: Jan 30 11:22:46.887: dot1xDoesPmkIdMatchPmk2, Received 11w Flag: 0
*DHCP Socket Task: Jan 30 11:24:17.893: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 313,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:24:17.893: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:24:17.893: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:24:17.893: ac:e0:10:ea:11:02 DHCP   xid: 0xfcafaaa1 (4239370913), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:24:17.893: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:24:17.893: ac:e0:10:ea:11:02 DHCP   ciaddr: 10.41.123.136,  yiaddr: 0.0.0.0
*DHCP Socket Task: Jan 30 11:24:17.893: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:24:17.893: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:24:17.894: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 313,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:24:17.894: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:24:17.895: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:24:17.895: ac:e0:10:ea:11:02 DHCP   xid: 0xfcafaaa1 (4239370913), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:24:17.895: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:24:17.895: ac:e0:10:ea:11:02 DHCP   ciaddr: 10.41.123.136,  yiaddr: 0.0.0.0
*DHCP Socket Task: Jan 30 11:24:17.895: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:24:17.895: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:24:17.896: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 313,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:24:17.896: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:24:17.896: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:24:17.896: ac:e0:10:ea:11:02 DHCP   xid: 0xfcafaaa1 (4239370913), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:24:17.896: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:24:17.896: ac:e0:10:ea:11:02 DHCP   ciaddr: 10.41.123.136,  yiaddr: 0.0.0.0
*DHCP Socket Task: Jan 30 11:24:17.896: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:24:17.896: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:24:17.898: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 313,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:24:17.898: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:24:17.898: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:24:17.898: ac:e0:10:ea:11:02 DHCP   xid: 0xfcafaaa1 (4239370913), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:24:17.898: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:24:17.898: ac:e0:10:ea:11:02 DHCP   ciaddr: 10.41.123.136,  yiaddr: 0.0.0.0
*DHCP Socket Task: Jan 30 11:24:17.898: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:24:17.899: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:24:17.901: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 313,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:24:17.901: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:24:17.901: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:24:17.901: ac:e0:10:ea:11:02 DHCP   xid: 0xfcafaaa1 (4239370913), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:24:17.901: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:24:17.901: ac:e0:10:ea:11:02 DHCP   ciaddr: 10.41.123.136,  yiaddr: 0.0.0.0
*DHCP Socket Task: Jan 30 11:24:17.901: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:24:17.901: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:24:17.903: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 313,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:24:17.903: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:24:17.903: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:24:17.903: ac:e0:10:ea:11:02 DHCP   xid: 0xfcafaaa1 (4239370913), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:24:17.903: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:24:17.903: ac:e0:10:ea:11:02 DHCP   ciaddr: 10.41.123.136,  yiaddr: 0.0.0.0
*DHCP Socket Task: Jan 30 11:24:17.903: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:24:17.903: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:24:17.905: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 313,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:24:17.905: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:24:17.905: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:24:17.905: ac:e0:10:ea:11:02 DHCP   xid: 0xfcafaaa1 (4239370913), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:24:17.905: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:24:17.905: ac:e0:10:ea:11:02 DHCP   ciaddr: 10.41.123.136,  yiaddr: 0.0.0.0
*DHCP Socket Task: Jan 30 11:24:17.905: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:24:17.905: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:24:17.907: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 313,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:24:17.907: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:24:17.907: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:24:17.907: ac:e0:10:ea:11:02 DHCP   xid: 0xfcafaaa1 (4239370913), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:24:17.907: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:24:17.907: ac:e0:10:ea:11:02 DHCP   ciaddr: 10.41.123.136,  yiaddr: 0.0.0.0
*DHCP Socket Task: Jan 30 11:24:17.907: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:24:17.907: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:24:17.909: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 313,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:24:17.909: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:24:17.909: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:24:17.909: ac:e0:10:ea:11:02 DHCP   xid: 0xfcafaaa1 (4239370913), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:24:17.909: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:24:17.909: ac:e0:10:ea:11:02 DHCP   ciaddr: 10.41.123.136,  yiaddr: 0.0.0.0
*DHCP Socket Task: Jan 30 11:24:17.909: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:24:17.909: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:24:17.912: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 313,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:24:17.912: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:24:17.912: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:24:17.912: ac:e0:10:ea:11:02 DHCP   xid: 0xfcafaaa1 (4239370913), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:24:17.912: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:24:17.912: ac:e0:10:ea:11:02 DHCP   ciaddr: 10.41.123.136,  yiaddr: 0.0.0.0
*DHCP Socket Task: Jan 30 11:24:17.912: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:24:17.912: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:24:17.913: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 313,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:24:17.914: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:24:17.914: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:24:17.915: ac:e0:10:ea:11:02 DHCP   xid: 0xfcafaaa1 (4239370913), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:24:17.915: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:24:17.915: ac:e0:10:ea:11:02 DHCP   ciaddr: 10.41.123.136,  yiaddr: 0.0.0.0
*DHCP Socket Task: Jan 30 11:24:17.915: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:24:17.916: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:24:17.917: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 324,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:24:17.917: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:24:17.917: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:24:17.917: ac:e0:10:ea:11:02 DHCP   xid: 0xfcafaaa1 (4239370913), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:24:17.917: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:24:17.917: ac:e0:10:ea:11:02 DHCP   ciaddr: 10.41.123.136,  yiaddr: 0.0.0.0
*DHCP Socket Task: Jan 30 11:24:17.918: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:24:17.918: ac:e0:10:ea:11:02 DHCP   server id: 10.2.25.22  rcvd server id: 10.2.25.22
*DHCP Socket Task: Jan 30 11:24:17.918: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 313,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:24:17.918: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:24:17.918: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:24:17.918: ac:e0:10:ea:11:02 DHCP   xid: 0xfcafaaa1 (4239370913), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:24:17.918: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:24:17.918: ac:e0:10:ea:11:02 DHCP   ciaddr: 10.41.123.136,  yiaddr: 0.0.0.0
*DHCP Socket Task: Jan 30 11:24:17.919: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:24:17.919: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:24:17.919: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 313,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:24:17.919: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:24:17.919: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:24:17.919: ac:e0:10:ea:11:02 DHCP   xid: 0xfcafaaa1 (4239370913), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:24:17.919: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:24:17.919: ac:e0:10:ea:11:02 DHCP   ciaddr: 10.41.123.136,  yiaddr: 0.0.0.0
*DHCP Socket Task: Jan 30 11:24:17.920: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
*DHCP Socket Task: Jan 30 11:24:17.921: ac:e0:10:ea:11:02 DHCP received op BOOTREPLY (2) (len 313,vlan 0, port 1, encap 0xec03)
*DHCP Socket Task: Jan 30 11:24:17.921: ac:e0:10:ea:11:02 DHCP processing DHCP ACK (5)
*DHCP Socket Task: Jan 30 11:24:17.921: ac:e0:10:ea:11:02 DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*DHCP Socket Task: Jan 30 11:24:17.921: ac:e0:10:ea:11:02 DHCP   xid: 0xfcafaaa1 (4239370913), secs: 0, flags: 0
*DHCP Socket Task: Jan 30 11:24:17.921: ac:e0:10:ea:11:02 DHCP   chaddr: ac:e0:10:ea:11:02
*DHCP Socket Task: Jan 30 11:24:17.921: ac:e0:10:ea:11:02 DHCP   ciaddr: 10.41.123.136,  yiaddr: 0.0.0.0
*DHCP Socket Task: Jan 30 11:24:17.921: ac:e0:10:ea:11:02 DHCP   siaddr: 0.0.0.0,  giaddr: 10.41.123.129
*DHCP Socket Task: Jan 30 11:24:17.921: ac:e0:10:ea:11:02 DHCP   server id: 10.154.25.22  rcvd server id: 10.154.25.22
Content for Community-Ad
Cisco COVID-19 Survey
