07-29-2013 04:50 AM - edited 07-04-2021 12:32 AM
I have a WLC2504 with three SSIDs configured and I have noticed that when my laptop connects to the main one it will only connect at 5.5Mbs. When I connect to the other two I get the full 72Mbps that my wireless card will allow. I have checked the SSID configuration but I cannot see anything that would cause this behaviour. Do you have any ideas/suggestions?
Thanks.
Gerry.
07-29-2013 03:30 PM
5.5 Mbps? That sounds like 802.11b. Can you check your SSID configuration and ensure Radio Policy is set to "All"?
07-30-2013 03:20 AM
I checked the SSIDs and all of them have all selected for the radio policy. Is there a command I can use to see how each SSID is configured so I can compare them and see whats different?
Gerry
07-30-2013 03:25 AM
Try "sh wlan ssid". Not sure, I don't have a WLC at home. Scott would know, he's got a WLC at home.
06-10-2014 05:03 AM
Which security options are enabled on that SSID?
06-04-2014 01:45 PM
Sometime it also happen due to co-channel interference, try by using setting up any other channel on 1st SSID and then check the connection speed.
06-10-2014 05:33 AM
HI Gerry,
I am not if its right or not but just check these :)
Check that are you using open aurhentication or WPA2/AES.
You can use a WLAN with NONE as Layer 2 Security or if you configure any Layer 2 security, 802.11n requires WPA2 AES enabled to operate at 11n rates.
May be u have diff security settings fro diff wlan.
06-10-2014 05:38 AM
Hi Guys,
Thanks for your suggestions on this but the issue is now resolved. Unfortunately I am not certain what resolved it as it went away after about 2 weeks.
Thanks!
