WLC 2504 stuck in SYS Amber blinking - ALM constant amber light -PWR Constant Green - no console
zayarnainghto0
I cant access my wlc with console
LED status= SYS-Amber blinking,ALM constant  amber PWR constant green.
Can I reset using reset port in front panel?
Please.
8 Replies 8
Leo Laohoo
If there is no console then the unit could be dead.
So what can I do for this?RMA is the only option ?
Yes. RMA.
Thanks Bro
you can reset the device using console. as per your details, device is in faulty mode. if you cannot get the console to the device, its better initiate a TAC with cisco and get a RMA.
regards,
Good luck
KB
Thanks for your information bro.
please mark as answer and rate helpfull if so :)
Good luck
KB
jturner2720
I assume you've tried the obvious first and powercycled the unit?
I've had numerous occasions where 5508s have got stuck with blinking alarm and no response on the console, but turning off and on again gets them back working again.
