WLC 4400 Not authetnicating between GUEST and Private networks
aremirez
I have a problem. I have a WLC 4400 and the problem i´m encountering is that when a user authetnicates to the private network, and then tryies to autheticate to the Guest network, it just stays there, it doens't do anything. Same way around, if you authenticate tothe Guest network, and change to the private network, it just sits there. I pointing that the problem is with Authentication, but not sure if i´m correct.
Can anyone help me?? what ifnormation will i need to retreive from the WLC to see where the problem lies??
I will get the debug mac addr <client-MAC-address           xx:xx:xx:xx:xx:xx> and repeat the issue in order to see if i get anything from the client.
Thanks for the help
Tony
i would check if its stucking on getting IP address or authenticating. Probaly try to manually set the IP when changing between networks and see if works.
umar bhatti
what authentation methods both networks are using. Also are you using different IP ranges for both networks.
Damon Garner
Try enabling fast change said in the controller general section.
Sent from Cisco Technical Support Android App
aremirez
Thanks for the help.
Actually the problem was that the WLC had a wrong time and also we had on our DHCP a 24 hour lease, so we were running low on IP´s.
Change the lease for 8 hours and set the time correctly and the issue got solved.
Thanks.
