Community Helping Community
311
Highlighted
Beginner
WLC 5508 7.3.112.0 System Crash
hi i got this situation.
model : wlc 5508
verstion : 7.3.112.0
our controllers working WLC1-active, WLC2-active, suddenly WLC1 went down and up (two times).
and normally working now. I cant figure out.
crash info
Number of files present is: 5
Beginning of Crash File: mwar_dump2.crash
Dumping registers
CPU Registers:
$ 0   : 00000000 1000cce1 00000002 00000000
$ 4   : ffffffff 00000001 00000001 00000000
$ 8   : 00000000 12800f70 12800f70 4b263328
$12   : 00000000 80000010 8117d240 10a1cfa8
$16   : 481596f8 4b263350 00000001 00000005
$20   : 4b263328 4b26332c 00010000 00000000
$24   : 00000070 11d53520
$28   : 131d1ce8 4b2632f0 1013c078 1013cb58
Hi    : 0000001f
Lo    : 33333362
Stack :
        00000000 00000001 00000000 48159848
        00000000 00000001 00000000 00000000
        00000004 00000000 000001a7 00000001
        4b4520f1 00000002 00000004 0025a6b5
        315ebc72 b1d6aebd 010d0000 00000000
        00000000 00000000 48159848 481597e0
        481598b0 48159918 48159980 481599e8
        48159a50 48159ab8 48159b20 48159b88
        48159bf0 48159c58 48159cc0 48159d28
        48159d90 48159df8 00000000 3381c438
        00000000 00000001 00000003 4b263320
        13201ce8 131f1ce8 131e1ce8 131d1ce8
        131f1ce8 131d1ce8 131e1ce8 131d1ce8
        13201ce8 131d1ce8 00000000 d8a5a096
        00000000 481596f8 00000000 00000001
        00000000 14114854 00000000 4b263a5c
*             Start Cisco Crash Handler                *
Sys Name:           Controller#1
Model:              AIR-CT5508-K9
Version:            7.3.112.0
Timestamp:          Tue Jan 28 20:43:09 2014
SystemUpTime:           351 days 19 hrs 6 mins 8 secs
signal:             11
pid:                1075
TID:                1260798800
Task Name:          apfRogueTask_3
Reason:           System Crash
si_signo:           11
si_errno:           0
si_code:            1
si_addr:            0x779
timer tcb:            0xa1f
timer cb:             0x10588ab0 ('rrmTimerInit+592')
timer arg1:           0x1bbd0530
timer arg2:           0x0
Long time taken timer call back inforamtion:
Time Stamp:           Tue Jan 28 20:43:09 2014
timer cb  :           10588ab0p('rrmTimerInit+592')
Duration  : 768804 usecs, cbCount= 2
Analysis of Failure:
  Software Failed on instruction at :
pc = 0x1013cc14 (DebugPrintRogueRRMneighbor+8480), ra = 0x1013cb58 (DebugPrintRogueRRMneighbor+8480)
  Software Failed while accessing the data located at :0x779
anyone can know about failed reason?  now we processing in rma. we going to change hardware 5days away.
2 ACCEPTED SOLUTIONS
VIP Mentor
Only Cisco TAC can analysis this & tells you exact reason of this reload. It looks like a software related crash..
I would suggest to move onto a later code (like 7.4.121.0) rather staying in 7.3 code when you get the new hardware.
Rasika
**** Pls rate all useful responses ****
Hall of Fame Master
Re: WLC 5508 7.3.112.0 System Crash
I agree with Rasika.... To sum the code, v7.0 is the most stable code but is limited due to the new hardware that it doesn't support. Only use v7.2 for FIPS and v7.3 and v7.5 will soon be deferred. v7.4 will be the version to stay with unless you require v7.6 for the 3700's or features.
-Scott
2 REPLIES 2
VIP Mentor
Rasika
Hall of Fame Master
-Scott
Content for Community-Ad
August's Community Spotlight Awards
