Community
Cisco announces new innovations in SD-WAN, ISRs, SD-WAN Services, and Catalyst 9000 Series switches
107
Beginner
WLC 5508 HA SSO Problem
Upgrading code on an HA pair that I have done many times I ended up in maintenance mode. As you can see from the attached file, it the new image was not transferred to the secondary. I can get to the secondary via the redundancy management IP given communication is down on the RP port. My question is can I just upgrade the secondary to the new image directly set the boot-loader to load the new image and reboot without affecting the in production primary. Thanks in advance.
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Guru
Re: WLC 5508 HA SSO Problem
I agree with Scott. Use the Service Port.
Hall of Fame Master
You should remove the connection and then use the service port to get in. Then you can tftp/ftp the image and upgrade. Then you can reboot and connect everything back. The wlc will boot up and the sync.
-Scott
Highlighted
Hall of Fame Guru
Beginner
Thank you both. Sounds like a plan.
