ā10-15-2013 10:37 AM - edited ā07-04-2021 01:05 AM
Hi All,
Today i am facing issue with mobility group. i checked and found control and data path is down on foreign controller.I am able to ping anchor controller. Required ports are open on firewall but mping and eping fails. Any idea whats wrong. On Anchor controller, i have 7 foreign controller configured and among these 3 are working fine. Having problem with 4 foreign controller. Previously all are working fine and there is no changes made on network or firewall.
ā10-15-2013 11:35 AM
Post output of "show mobility summary" of your Anchor WLC & a non-working WLC. Also "show sysinfo" of those two controllers.
Rasika
ā10-15-2013 12:00 PM
Have you verified the IP and Mac address of both the anchor and foreign controllers are correct in the mobility group config
Sent from Cisco Technical Support Android App
ā10-15-2013 08:32 PM
Issue is resolved after rebooting Anchor controller. Now all foreign controller is up and working fine for Guest network. Can you please help me to find the reason?
