WLC ap_count license issue
zwjames056
Dear Support,
I'd two WLCs (for Serial Number FCH2037V357 & FCH2035V4GU), and take total 94 ap_count license in the same case.
But now I find that, the license were shared with two WLCs automatically, then the ap_count are 97 on my WLC (by 50 default and 94/2=47 ap_count license). It's not meets requirements with my Architecture, now I want take 10 ap_count licenses from a WLC (serial number : FCH2037V357) to the other (serial number : FCH2035V4GU), for 87 ap_count with FCH2037V357 and 107 ap_count with FCH2035V4GU, what can I do for that?
Best Regards,
Adonis
2 Accepted Solutions
sandjose_cisco
If it is 8540/5520/7500/8500 you can move the license by yourself since it is RTU based
If you are using 5500 then it is honor based , contact  Cisco TAC to have the license moved
Hi Adonis,
You have some private information posted here and I don't think anyone here wants to see that.I suggest you may black out the private stuff.
See here . 5520 carry RTU licenses if you have purchase enough for your project.you can move them around in any combination as long as it doesn't exceed total amount
Cheers
Prabath
**Please rate all the useful answers**
***Please rate all the useful posts***
-Prabath
sandjose_cisco
Hi Adonis,
Cheers
Prabath
-Prabath
zwjames056
Hi Sir,
It's work, my WLC type is 5520, and I trun the license type to RTU, now I move the ap_count to the other WLC successful. thanks a lot.
Adonis
