03-26-2019 11:41 AM - edited 07-05-2021 10:08 AM
We are going to upgrade WLC ap licese.
Could someone please guide me to the required steps.
Solved! Go to Solution.
03-26-2019 10:56 PM
if you are using 2504/5508/8510 or older models then there is no smart licensing available.
For the above mentioned products ...here are the steps to upgrade:
http://justdowifi.blogspot.com/2013/02/how-to-add-ap-licenses-to-cisco-5508.html
for new products(RTU):
Dont forget to rate helpful posts
03-26-2019 09:38 PM
03-26-2019 10:56 PM
03-28-2019 12:41 AM
03-28-2019 01:18 AM
I think you are using the 2504 WLC as HA controller(secondary). If your primary will be down then seconadry will takeover.
