Showing results forĀ
Search instead forĀ
Did you mean:Ā
WLC authorisation logs
voval
Im working currently with WLC 2504 running version 8.0.110.0. I configure new SSID that working with RADIUS.
I want to map user-id to IP on my firewall (Paloalto). I found few documents (https://live.paloaltonetworks.com/t5/Integration-Articles/Use-Syslog-Receiver-to-Integrate-with-Cisco-Wireless-Controller/ta-p/52824) describing how to do it with SNMP traps that converting it to syslog and forwarding to firewall, i have to admit that i dont like the idea to have another server in the middle.
I found that its possible to run the following commands in order to generate a syslog:
config logging syslog facility client authentication
config logging syslog facility client associate
After running the commands i can see the logs
WLC_NAME: *Dot1x_NW_MsgTask_2: Feb 08 14:38:49.791: #APF-3-AUTHENTICATION_TRAP: apf_80211.c:15520 Client Authenticated: MACAddress:18:65:90:48:e0:3a Base Radio MAC:0c:68:03:2c:fc:d0 Slot:1 User Name:MYUSERNAME Ip Address:192.168.237.101 SSID:MYSSID
I configured to send it to Paloalto but i cant configure the receiver correctly. (based on this article: https://live.paloaltonetworks.com/t5/Integration-Articles/Use-Syslog-Receiver-to-Integrate-with-Cisco-Wireless-Controller/ta-p/52824)
I wonder if someone ever did it and it worked? Any help will be appreciated
PERI_Admin
I know that your question is two years old but we did a similar setup the last weeks. So let me point out how it's working for us. We use PAN-OS 8.1.9.
The following command on WLC is everything you need:
logging syslog facility client associate enable
After that configure Palo Alto firewall as syslog server on WLC.
On Palo Alto firewall you should create a Syslog Parse Profile with the following entries:
Basically that's everything you need to get it running.
