06-03-2014 08:27 AM - edited 07-05-2021 12:56 AM
Hello all
I'm looking for stability information on 7.6.120.0. I have recently been told by TAC that an issue I am having is resolved in 7.6.120.0 and seeing as it is the newest version of 7.6 I want to make sure that there are not connectivity issues for clients and there are no issues on MESH network.
The controller is a 5508 running 7.6.100.0 and has many mesh links. the roots are 1522 and 24 and the mesh APs are 1522, 1524 and 1242. The bug that is being fixed is CSCui86001.
06-03-2014 09:03 AM
yes 7.6.120.0 version is ok :
Please check for open caveats :
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn76mr02.html#pgfId-1163066
06-03-2014 11:52 AM
this one worries me as those are the types of SSIDs I use. I am not currently having it in 7.6.100.0
I cannot just reboot this controller as I have wire VoIP devices that rely on the mesh connections.
I was also hoping to hear from people who are using this release in Production and if they have had issue or if it has been stable.
06-03-2014 12:25 PM
Yes this issue is resolved in 7.6.120.0.
https://tools.cisco.com/bugsearch/bug/CSCun62368
This is pretty new version so not many have this is in production.
Suggest: Always keep the second highest version for your controller , its a best practice to have because of new bugs in new version .
You have 2 bugs, one in 7.6.100. and othe rin 7.6.120.0.
06-03-2014 01:20 PM
SO to fix on thing I need to go to 7.6.120.0 but that could cause me issues.
If you had to choose between 7.6.110.0 and 7.6.120.0 which on would you choose as the one I have right now is deferred.
06-04-2014 06:34 AM
I think you should go to with 7.6.120.0.
06-03-2014 08:43 PM
Best bet is to load in a lab and then slowly push out. Sometimes the bugs listed may never impact you, instead you may find yourself finding the undocumented ones. I have a friend in mining who has a large mesh network and I understand he is on 7.6.120.0.
I don't have any mesh on my controller with 7.6.120.0.
06-04-2014 05:32 AM
Unfortunately my company does not have a lab environment I would love to but the funds are not there.
Have you had any issue with client access on your controller?
The bug I pointed out below actually will not affect me as I don't use NAC on my SSIDs.
