06-03-2020 04:20 AM - edited 07-05-2021 12:08 PM
Hi Team,
Need your inputs on the below query. I need to upgrade the code on 3504 in HA mode to 8.5.161 from 8.5.135.
Please ensure if the steps below are good to upgrade code without breaking the HA.
1. Save current config. Copy the 8.5.161 image from TFTP to controller.
2. Predownload image on all the access points.
3.Save config
4. Go the GUI, save the configuration and reload both the systems at the same time from commands tab in controller.
Please help with your suggestions.
06-03-2020 04:31 AM
06-03-2020 02:52 PM
Refer below for detailed steps. You have to swap images once pre-download and initiate the failover, in order to reduce downtime.
1.After the WLCs are configured in the HA setup, the Standby WLC cannot be upgraded directly from the TFTP/FTP server.
2.Initiate upgrade on the Active WLC in the HA setup via CLI/GUI, and wait for the upgrade to finish.
3.Once the Active WLC executes all the upgrade scripts, it will transfer the entire image to the Standby WLC via the Redundant Port.
4.When the Standby WLC receives the image from the Active WLC, it will start executing the upgrade scripts. The transfer of the image to standby and the execution of the upgrade scripts on the Standby WLC can be seen on the Active WLC Console/Telnet/SSH/Http connection.
5.After a successful message of Standby Upgrade is observed on the Active WLC, it is important to issue the show boot command on the Active WLC in order to make sure the new image is set as the primary image.
6.Once verified, initiate primary image pre-download on the Active WLC in order to transfer the new image to all the APs in the network.
7.After pre-image is completed on all the APs, issue the show AP image all command in order to verify that the primary image on the WLC is set as the backup image on APs.
8.Initiate swap option to interchange the backup image as primary on the APs. With this implementation, the WLC's and AP's primary image is set to the new image.
9.Issue the schedule-reset command as per planned outage with the no swap option in order to reset the APs and WLCs so that they can boot with the new image.
10.All the APs will reboot and join the new Active WLC.
11.Issue the show boot, show sysinfo, show ap image all, and show redundancy summary commands in order to verify that both the WLCs and APs have booted with the new image.
Rasika
*** Pls rate all useful responses ***
