Highlighted
Re: WLC Config Converter
Yes, that the correct option you’d need to choose . The tool will highlight the portions of your 5508 config (like encryption and port config ) that you’d need to manually edit and save to port as coming into 3504 . Please plug in a 5508 backup config file into the tool and you will understand.
Highlighted
Contributor
Thanks for maintaining this. Consider putting aireos to ios xe conversion utility in the post so it will turn up in google searches.
How often is this tool updated?
Highlighted
Thank you for the feedback. I have updated the title now.
Content for Community-Ad
